[mapserver-users] oracle8.1.7 and mapserver
Yu-Hsin Chen
ychen at yorktel.com
Fri Nov 15 15:12:19 EST 2002
Nida:
MapServer's connection to Oracle is taken care of by the underlying SQLNet. Judging from you did not get any error message I think you're connected to Oracle OK.
How about try to stick the following in your map file in the CLASS section:
SYMBOL 4
SIZE 3
right between your NAME and COLOR lines. Of course you need to have a symbol file and 4 need to be defined.
Yu-Hsin
-----Original Message-----
Sent: Fri 11/15/2002 12:19 PM
To: Yu-Hsin Chen; mapserver-users at lists.gis.umn.edu
Cc:
Subject: Re: [mapserver-users] oracle8.1.7 and mapserver
Hi Again,
my counties table does have a sdo_geometry data type
here is desc of my table
SQL> desc counties
Name Null? Type
GEOM MDSYS.SDO_GEOMETRY
COUNTY VARCHAR2(31)
FIPSSTCO VARCHAR2(5)
STATE VARCHAR2(30)
STATE_ABRV VARCHAR2(2)
FIPSST VARCHAR2(2)
LANDSQMI NUMBER
TOTPOP NUMBER
POPPSQMI NUMBER
I am wondering how mapserver knows where the database resides?
Where do I define my database connection parameters??
IS there any quick test to find out if mapserver is looking into right database?
My database is on remote machine and I'm running mapserver from my machine...
I also have oracle client on my machine talking to same database.
I heartly appreciate your help!
Kind Regards
Nida.
----- Original Message -----
To: nida Khan ; mapserver-users at lists.gis.umn.edu
Sent: Friday, November 15, 2002 5:15 PM
Subject: RE: [mapserver-users] oracle8.1.7 and mapserver
Nida:
Judging from your 'counties table with a column geom' it doesn't appear to me you're using Oracle Spacial option. You will need to have that option to work with MapServer. Is your 'geom' column of data type SDO_GEOMETRY?
You have to make sure Oracle Spacial option is in the database. By default, when spacial option is installed you'll have an MDSYS user id and schema associated with that user. If you don't see that, you'll have to install it first. You should have an 'md' directory under $ORACLE_HOME. Under md there is an admin directory which contains all installation scripts.
Your map file looks OK if your counties is a table contain geom column which is of SDO_GEOMETRY data type.
Yu-Hsin
Sent: Friday, November 15, 2002 9:48 AM
I gave wrong example! :(
here is the right example
layer defination
LAYER
NAME counties
TYPE polygon
STATUS default
MAXSCALE 1000000
CONNECTIONTYPE oraclespatial
CONNECTION 'scott/tiger at PHAR'
DATA "GEOM from counties"
CLASS
NAME 'county'
COLOR 220 224 230
OUTLINECOLOR 0 0 0
END
END
where I have counties table with a column geom
very anxious!
Regards
Nida.
Sent: Friday, November 15, 2002 1:34 PM
Nida:
You need to compile MapServer with oraclespacial.
Your Oracle RDBMS needs to have Spacial option loaded. Hopefully you've already got this part, it is a good learning curve if you havn't.
What web server are you using? You might need to modify the configuration a little.
Once you have all the correct environment and settings it WILL work. I'm running MapServer on a Mandrake Linux server accessing Oracle 8.0.5 data on a UnixWare server through CGI.
Yu-Hsin
Sent: Friday, November 15, 2002 6:29 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] oracle8.1.7 and mapserver
Hi Everyone,
Is there anyway to connect to Oracle 8.1.7 database on Solaris via Mapserver?
I've compiled Mapserver with Postgress, but have no idea how to do it for Oracle now!
I would really appreciate if anyone can guide me to right documentation or just give me some codes!!!!
Looking forward for your replies
Regards
Nida.
