[mapserver-users] gdal with jpeg2000
Drew Simpson
atsimpson at directvinternet.com
Sat Nov 16 19:46:46 EST 2002
Has anyone had any success with the csv version of gdal and mapscript?
I downloaded, compiled and installed jasper.
I downloaded, compiled and installed the latest gdal from the csv.
Jasper and gdal command line utilities seem to work fine.
Am able to convert tif's to jp2, etc.
I downloaded and compiled mapserver.
mapserv works fine:
I successfully compiled and installed mapscript, but if I try and use it I
get
Can't load
'/home/asimpson/lib/site_perl/5.6.1/i386-linux/auto/mapscript/mapscript.so'
for module mapscript:
/home/asimpson/lib/site_perl/5.6.1/i386-linux/auto/mapscript/mapscript.so:
undefined symbol: IsLocal__19OGRSpatialReference at
/usr/lib/perl5/5.6.1/i386-linux/DynaLoader.pm line 206.
at /home/asimpson/lib/site_perl/5.6.1/i386-linux/mapscript.pm line 7
Compilation failed in require at ./jp2_test.pl line 10.
BEGIN failed--compilation aborted at ./jp2_test.pl line 10.
To further complicate the issue, all software is installed under my account,
but I think I have my environment pointing to all the local installs.
Probably showing my ignorance with this post, but have run out of ideas.
Any help would be great,
Thanks Drew.
===================== UNAME OUTPUT ========================
$ uname -a
Linux mymachine 2.4.18-10 #1 Wed Aug 7 11:39:21 EDT 2002 i686 unknown
===================== PERL SCRIPT =========================
#!/usr/bin/perl
use lib '/home/asimpson/lib/site_perl/5.6.1/i386-linux'; # mapscript
location
use mapscript;
===================== MAPSERV OUTPUT ======================
./mapserv -v
MapServer version 3.6.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=JPEG INPUT=GDAL
INPUT=SHAPEFILE
===================== LDD OUTPUT ==========================
ldd
libgdal.1.1.so => /home/asimpson/lib/libgdal.1.1.so (0x400df000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40259000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40277000)
libpng.so.2 => /usr/lib/libpng.so.2 (0x402b6000)
libz.so.1 => /usr/lib/libz.so.1 (0x402d8000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x402e6000)
libm.so.6 => /lib/i686/libm.so.6 (0x40334000)
libc.so.6 => /lib/i686/libc.so.6 (0x42000000)
libungif.so.4 => /usr/lib/libungif.so.4 (0x40356000)
libdl.so.2 => /lib/libdl.so.2 (0x4035e000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0x40361000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x403a4000)
