[mapserver-users] WMS layer is blank
Dylan Keon
keon at nacse.org
Tue Nov 19 00:56:28 EST 2002
>>I'm trying to display a WMS layer (Terraserver DOQ) in a simple
>>interface. I've tried everything I can think of to get it to display,
>>but just get a blank image. The extent and epsg codes are correct. The
>>other layer in the mapfile (a shapefile) appears, but not the WMS layer.
>>I compiled MapServer with --enable-debug...the WMS request URL printed
>>to the server log is good. I can copy that URL to a browser and the
>>correct DOQ image appears. The mapfile is below. Thanks for any help.
> I was able to reproduce this problem with MapServer 3.6 and filed a bug
> in bugzilla: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=223
> Note that we've been doing some work (with Frank W.) recently to improve
> WMS support in 3.7 and the layer does show up in 3.7... so it might be
> worth a try if you are able to compile the latest 3.7 from CVS.
OK, thanks. I've been trying to compile 3.7 but run into a consistent
error (see below). Seems to be a problem with mappdf from libwww. I'm
compiling against libwww-5.4.0. Any suggestions? 3.6.3 compiles just
fine using exactly the same configuration.
Thanks,
Dylan
gcc -c -g -O2 -Wall -DENABLE_STDERR_DEBUG -DIGNORE_MISSING_DATA
-DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR
-DUSE_WFS_LYR -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT -DUSE_PDF -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS -DUSE_THREAD
-I/usr/local/src/gd-1.8.4 -I/usr/local/src/proj-4.4.5/src
-I/usr/local/src/gdal-1.1.7/ogr/ogrsf_frmts
-I/usr/local/src/gdal-1.1.7/ogr -I/usr/local/src/gdal-1.1.7/ogr/../port
-I/usr/local/src/gdal-1.1.7/port -I/usr/local/src/gdal-1.1.7/core
-I/usr/local/src/gdal-1.1.7/ogr/ogrsf_frmts -I/usr/local/pgsql/include
-I/usr/include -I/usr/include/w3c-libwww -DHAVE_CONFIG_H mappdf.c -o
mappdf.o
mappdf.c: In function `msFreeImagePDF':
mappdf.c:975: union has no member named `swf'
mappdf.c: In function `msDrawTextPDF':
mappdf.c:1027: warning: assignment makes integer from pointer without a cast
make: *** [mappdf.o] Error 1
