[mapserver-users] Mapscript alternatives
Nicolas Boretos
nicolasb at maich.gr
Tue Nov 19 02:30:44 EST 2002
Sean Gillies wrote:
> Adam,
> PHP is the best supported flavor of mapscript, but will be
> the more limiting. It may very well provide everything
> you need.
> Perl mapscript is less well supported than PHP, but more
> powerful. It gives you the option of hooking up many other
> great modules to your mapscript apps. Perl is not going to
> be very easy to learn for someone with no C experience,
> and there is also the issue of a major Perl language revision
> on the horizon.
> Python mapscript is even less well supported than Perl. Only
> sketchy documentation (my fault as much as anyone's). It is
> much more easy to learn than Perl and also allows you to
> exploit many useful packages. For my recent employer, I wrote
> a Python mapscript app that used the Python Imaging Library
> to combine raster layers and apply custom image enhancements
> on-the-fly. I could have done this with Perl, perhaps, but
> not with PHP.
Even more obscure is the TclMapscript interface, which like Perl above,
allows hooking/combining numerous libraries into your mapping
application. A very powerfull combination is running
mapserver/tclmapscript under tclhttpd, a powerfull web application
server written in tcl.
I believe though, that on WIN, tclmapscript binary is based on MS3.4
regards,
nicolas boretos
> cheers,
> Sean
