[mapserver-users] WMS layer is blank
Frank Warmerdam
warmerdam at pobox.com
Tue Nov 19 22:00:38 EST 2002
Dylan Keon wrote:
> I successfully compiled the latest 3.7 CVS version (thanks Frank,
> Assefa, and Daniel), and can report that this version is able to display
> WMS layers retrieved from terraservice.
> However, now I seem to be running into the 24-bit vs 8-bit problem (I
> think). The DOQ image retrieved directly into the browser looks great,
> but the image retrieved and rendered by MapServer looks pretty bad.
> Please have a look at http://www.nacse.org/~keon/temp/wms to see what I
> mean. Ignoring the issues about 24-bit file size vs. 8-bit, etc. for
> the moment, any suggestions on how to get the good-looking image in my
> interface? :-) I'm using gd 1.8.4, would switching to 2.0.7 help?
Dylan,
If you upgrade to GD 2.x then you can use MapServer 24-bit mode. You would
also need a declaration something like this in your mapfile:
IMAGETYPE png24
OUTPUTFORMAT
NAME png24
DRIVER "GDAL/PNG"
IMAGEMODE RGB
TRANSPARENT OFF
END
Actually, returning JPEG data (like the terraserver) might be much better:
IMAGETYPE jpeg24
OUTPUTFORMAT
NAME jpeg24
DRIVER "GDAL/JPEG"
IMAGEMODE RGB
TRANSPARENT OFF
END
I have also been considering implementing a dithering scheme in MapServer
for converting 24bit to 8bit. Would you be willing to test it if I
implemented it?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
