[mapserver-users] 24bit to 8 bit with dithering
    Frank Warmerdam
    warmerdam at pobox.com
    Tue Nov 19 21:37:15 PST 2002
Folks,
I have completed implementation of 24bit to 8bit dithering in the draw-from
GDAL code.  It turns out this requires the very latest GDAL (ie. build from
CVS later than right now), so I require the ENABLE_DITHER macro to be
added to the makefile.
Dithering is enabled if the PROCESSING keyword is used with the layer to
set the "DITHER=ON" directive. Currently the dithering uses the existing
color table (that created by the usual color cube logic), so results are
still questionable, but better than they were.  I am also interested in
incorporating optimal colortable selection at some point.
I would also note that the approach is pretty cpu intensive, and there is
a fair overhead per raster file processed, so using it for many 24bit "tiles"
from separate files in a single draw would be the worst case.  This
technlogy is not appropriate for servers wanting to maximize performance.
The following is an example of using the new support:
NAME TEST
STATUS ON
SIZE 400 300
EXTENT 0 0 400 300
IMAGECOLOR 255 255 0
PROJECTION
   "proj=utm"
   "zone=12"
   "datum=WGS84"
END
IMAGETYPE png8_t
OUTPUTFORMAT
   NAME png8_t
   DRIVER "GD/PNG"
   IMAGEMODE PC256
   TRANSPARENT OFF
END
LAYER
   NAME grey
   TYPE raster
   STATUS default
   DATA data/pct22.tif
   PROJECTION
     "proj=utm"
     "zone=12"
     "ellps=WGS84"
     "towgs84=1,0,0"
   END
END
LAYER
   NAME rgb
   TYPE raster
   STATUS default
   DATA data/rgb.tif
   OFFSITE 111 222 111
   PROCESSING "DITHER=ON"
   PROJECTION
     "proj=utm"
     "zone=12"
     "ellps=WGS84"
     "towgs84=1,0,0"
   END
END
END # of map file
The output without dithering as a colormapped png file (2.8K) is:
   http://pobox.com/~warmerdam/rgb_overlay_res_to8bit.png
With dithering (18K) is:
   http://pobox.com/~warmerdam/rgb_overlay_res_to8bit_dithered.png
Anyone brave enough to build the latest GDAL and MapServer 3.7 from CVS
are welcome to contact me for help in using the new dithering option.
Best regards,
More information about the MapServer-users
