[mapserver-users] [Fwd: About setfilter in layer object]
William A. Bronsema, C.E.T.
bronsema at dmsolutions.ca
Wed Nov 20 11:09:07 EST 2002
-------- Original Message --------
Subject: About setfilter in layer object
Date: Mon, 18 Nov 2002 16:00:24 +0000
From: "ajimenez at ecosconsult.com.br" <ajimenez at ecosconsult.com.br>
Hello William:
I write you because i have a litter question, the setfilter() method of
the layer object work fine for PostGIS data when the filter condition is
over a non integer data field in the database?, i am do some test using
setfilter() and this method only work fine when the filter field is an
integer, if it is a string or float field the setfilter() don't work.
What you can say me about this.
Best Regards,
Lic. Amaury Jiménez Marrero
EcosConsult.
R. Mons. Ivo Zanlorenzi 847 cj.4
Curitiba. PR.
Brasil.
80.740-590
Telef: ++55-41-3391461
