[mapserver-users] Coordinate transformation in Java (latlong
to LCC)
Jean-Francois.Doyon at ccrs.nrcan.gc.ca
Wed Nov 20 14:37:59 EST 2002
Hello,
I once upon a time fumbled upon a SWIG interface for PROJ.4 ... It was
written for use with SWIG/Python, but maybe you could fairly easily use it
to generate a Java interface ? Find it attached.
Good luck!
J.F.
-----Original Message-----
From: Michael Soracco [mailto:Michael.Soracco at noaa.gov]
Sent: Wednesday, November 20, 2002 1:07 PM
To: Jan Kunzmann
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Coordinate transformation in Java
(latlong to LCC)
Jan-
Here's a class that will do it using the equations per Snyder's Handbook (as
seen
in GCTP). Although I did not write the snipet (I can put you in contact
with the
original author offline if needed), I have used it routinely in a Java
applet. You
will see comments in the code describing the inputs (XY) and a parameter
array
which identifies the SP1,2 , ellipsoid, etc.
-m
Jan Kunzmann wrote:
> Hi there folks,
> I know this is a kind of of-topic question, but I really need help...
> I need to convert lat-long coordinates to Lambert Conic Conformal (2SP)
> coordinates and vice versa, as figured at
http://www.remotesensing.org/geotiff/proj_list/lambert_conic_conformal_2sp.h
tml
> I already found the PROJ.4 library being capable of doing this simple
> conversion, but I need to do it in Java. I searched the web and found
> some complex packages, but they are too complicated to understand for
> me, and none of them is as easy as
> (x,y) := convert(x,y, originlat, originlong, sp1lat, sp2lat)
> Does anyone know where I can find such a class, or can send me the
> algorithm (it's already on the remotesensing page but it's unreadable
> for me...)?
> Thanks in advance,
> Jan
Michael Soracco
SES, Inc. for NOAA/NESDIS
at NOAA Science Center (WWB)
5200 Auth Road, Room 607
Camp Springs, MD 20746
Voice: 301.763.8142 x117
FAX: 301.763.8131
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021120/86bc8687/pyProjectionLib-0.2.obj
