[mapserver-users] Fatal error: Call to undefined function:
querybyattributes()
Armin Burger
armin.burger at libero.it
Thu Nov 21 07:33:13 EST 2002
David,
for more than one item I don't know exactly if this kind of definition works. A filter definition like the following should work anyway:
setFilter("('[YOUR_FIELD]'='3c84fb819c517' OR '[YOUR_FIELD]'='3c691cde3d1a7')")
with the field names (at least for shapefiles) in upper case.
Armin
> Hi,
> I've been able to use querybyattributes on a layer, thanks to Daniel's
> help.
> It works fine with a single item :
> $oLayer = $gpoMap->getlayerbyname("connexions"); //get
> neighborhood layer
> $oLayer->setfilter("\"3c84fb819c517\"");
> $oLayer->querybyattributes(MS_MULTIPLE);
> $img = $gpoMap->drawQuery();
> But I can't find the syntax for a multiple query. I tried :
> $oLayer->setfilter("\"3c84fb819c517\"|\"3c691cde3d1a7\"");
> But it does not seem to work. The query only returns the first point.
> Has any got the right syntax?
> Thanks
> David Boggio
> -----Message d'origine-----
> De : owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu] De la part de Daniel
> Morissette
> Envoyé : jeudi 21 novembre 2002 03:13
> À : David Boggio
> Cc : mapserver-users at lists.gis.umn.edu
> Objet : Re: [mapserver-users] Fatal error: Call to undefined function:
> querybyattributes()
>> David Boggio wrote:
>> I have installed Mapserver 3.6.1, and I'm trying to use the
>> QueryByAttributes function in my script. But I keep getting this error
>> message :
>> Fatal error: Call to undefined function: querybyattributes()
> Note that queryByAttributes() is available only in the layerObj. Are
> you using $map->queryByAttributes() by any chance?
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Incoming mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.417 / Virus Database: 233 - Release Date: 08/11/2002
> Outgoing mail is certified Virus Free.
> Version: 6.0.422 / Virus Database: 237 - Release Date: 20/11/2002
