[mapserver-users] creating truetype font files
randy james
rjames57 at yahoo.com
Thu Nov 21 16:05:08 EST 2002
I've had a few problems with fonts on my system, i was
using a font that did not use unicode mapping and had
the problems you discribe. When you added the glyph to
0033 was the glyph the shape of an explanation mark? I
ask because all the problems i had were related to the
fact that when the glyph at a unicode cell was not the
glyph that should have been there, the character did
not show up.
hope this helps
Cheers
--- Peter.Bruton at ccrs.nrcan.gc.ca wrote:
> Hello;
> I am trying to create a truetype font file for use
> in MapServer. My
> Mapserver install in version 3.6.3 on a LINUX
> platform.
> To create the font, I used High Logic's Font Creator
> 3.1.1. I selected
> "Unicode" as the font template. For testing
> purposes I simply added 1 glyph
> at the font cell with the exclamation point caption.
> After saving the newly
> created font, I installed it on my PC (Microsoft
> Windows 2000 OS). Then I
> viewed the font file using the OS's Character Map.
> The glyph appeared
> correctly. I then opened up Microsoft WORD and
> tested the font. The font
> correctly rendered the glyph.
> After transferring the new font file to my LINUX
> box, I used FreeType's
> "ftdump" to examine the fonts properties. They were
> as follows:
> [bruton at grumbler fonts]$ ftdump mysecondfont.ttf
> There is 1 face in this file.
> ----- Face number: 0 -----
> font name entries
> family: NewUnicodeFont
> style: Regular
> postscript: NewUnicodeFont
> font type entries
> FreeType driver: truetype
> sfnt wrapped: yes
> type: scalable
> direction: horizontal
> fixed width: no
> glyph names: yes
> EM size: 2048
> global BBox: (25,0):(1280,1280)
> ascent: 1854
> descent: -434
> text height: 2355
> charmaps
> 0: platform: 1, encoding: 0
> 1: platform: 3, encoding: 1
> Based upon the results of previous ftdumps I
> performed on truetype fonts
> files (ESRI truetype fonts such as esri_39.ttf and
> esri_33.ttf) I have
> successfully used in a MapServer map file to
> symbolize points, I expected
> this font to work properly. It seems that MapServer
> accepts "Windows
> Unicode" as a valid character mapping (platform = 3
> and platform specific
> encoding = 1).
> I added the new font file to the "fonts.list" file
> and then added a new
> symbol based upon this file to my "symbols.sym"
> file.
> SYMBOL
> NAME uuuuuu
> TYPE TRUETYPE
> FONT mysecondfont
> FILLED TRUE
> ANTIALIAS TRUE
> CHARACTER "!"
> END
> This symbol was then used to symbolize points from
> an ArcView point
> shapefile. The points were being successfully
> rendered when I used a
> previously defined symbol. However, when I changed
> the existing symbol to
> the newly added symbol, the points were no longer
> rendered on the map.
> Another interesting behavior is the font files
> appearance in MapLab. My
> organization uses DM Solutions MapLab (2.0rc2) to
> create/edit and maintain
> map files. The MapEdit module of MapLab displays a
> sample of all font files
> contained in the "font.list" file when a map author
> clicks on the "Font"
> property of a Classes Label object. With the
> exception of the font file I
> created, all other fonts have characters displayed.
> Any assistance in creating valid truetype font file
> is appreciated.
> Have a good day.
> Peter Bruton
> GeoAccess Division
> Canada Centre for Remote Sensing
> 615 Booth Street, Room 650
> Ottawa, Ontario, K1A 0E9, Canada
> telephone 1-613-947-0465
> fax 1-613-947-2410
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
