[mapserver-users] vmap0 to shape file
Administrator
jnovak at novacell.com
Sat Nov 23 20:37:10 EST 2002
I'm using OGDI VPF to read these files and there's no limit on the input
file size that I know of, other than available memory.
John Novak
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Saturday, November 23, 2002 11:32 AM
To: woodbri at swoodbridge.com
Cc: Mapserver-Users
Subject: Re: [mapserver-users] vmap0 to shape file
woodbri at swoodbridge.com wrote:
> OK, I tried this, if you don't have the xvt libraries and includes it
> will not be easy and will only be fun if you like pain and headaches.
> Frank,
> Does ogr2ogr support converting VPF to shapefiles?
> What is the command syntax?
> What are the limits on conversion?
Steve,
Yes, ogr2ogr can be used to translate VPF to shapefile, if you have a
build with OGDI support (such as the OpenEV_FW binary builds). For
instance, to extract the political boundaries you might do this:
warmerda at gdal[589]% ogr2ogr polbnda.shp
gltp:/vrf/usr4/mpp1/v0noa/vmaplv0/noamer
'polbnda at bnd(*)_area'
warmerda at gdal[590]% ls -l polbnda*
-rw-r--r-- 1 warmerda users 1052287 Nov 22 11:58 polbnda.dbf
-rw-r--r-- 1 warmerda users 327 Nov 22 11:57 polbnda.prj
-rw-r--r-- 1 warmerda users 10335532 Nov 22 11:58 polbnda.shp
-rw-r--r-- 1 warmerda users 85980 Nov 22 11:58 polbnda.shx
In the dataset name 'gltp:/vrf/usr4/mpp1/v0noa/vmaplv0/noamer' the
gltp:/vrf part is not really in the filesystem. The VPF data was at
/usr4/mpp1/v0noa. The "noamer" directory should be at the same level as
the dht. and lat. files.
The resulting political boundaries seem to include a "nam" attribute
with the state names/province names. Not too sure about namtional level
boundaries. I couldn't browse around in the data very easily since it
was still fairly large.
The limits? I'm not too sure what issues you will run into. The data
model is VPF as exposed through the OGDI VPF (vrf) driver.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
