[mapserver-users] Re: Annotations not appearing on map with phpMapscript - Solved
NVohra at eq-technologic.com
Tue Nov 26 04:59:24 EST 2002
Hello,
I have figured out the solution for the problem.
Thanx,
Nischal Vohra
That one last shot's a Permanent Vacation
And a how high can you fly with broken wings
Life's a journey - not a destination
And I just can't tell just what tomorrow brings -
Aerosmith
Nischal Vohra
To: mapserver-users at lists.gis.umn.edu
11/26/02 02:30 cc:
PM Subject: Annotations not appearing on map with phpMapscript
Hello,
I have PHP ver4.0.6 with MapScript Version (Nov 27, 2001) and
MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE on WinNT.
I need to put annotations in the map, after user zooms-in to some
level.
My map file looks like this :
LAYER
NAME line3
TYPE annotation
DATA linedata
STATUS DEFAULT
LABELCACHE on
LABELITEM "LABEL"
CLASSITEM "LABEL"
CLASS
EXPRESSION ([ID] == 0) #to avoid showing annotation on
start
NAME "lblclass"
OUTLINECOLOR 199 216 252
COLOR 199 216 252
LABEL
ANGLE AUTO
BUFFER 3
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
POSITION cc
FORCE true
BACKGROUNDCOLOR 255 255 255
END
END
END
My php file has code like this :
if ($zoomlevel >= 4)
$layer = $map->getLayerByName('line3');
$layer->annotate = 1;
$class = $layer->getClass(0);
$class->setExpression("([ID] == 15004 || [ID] == 14683)");
$class->color = "255 136 136";
$layer->classitem="LABEL";
$class->label->autoangle = 1;
$class->label->buffer = 3;
$class->label->font = "aerial";
$class->label->type = MS_TRUETYPE;
$class->label->size = 8;
$class->label->color = $map->addColor(0,0,0);
$class->label->outlinecolor = $map->addColor(199,216,252);
$class->label->position = MS_CC;
$layer->draw($image);
I went through mailing list and did changes like
$layer->annotate = 1; and
But still annotations are not coming on map. They work if loaded
directly from map file by keeping
status of layer "ON", but then they stay on always and I am unable to
control them.
Nischal Vohra
Aerosmith
