[mapserver-users] Starange results- vmap0 to shape file
Emmanuelle
bultee at yahoo.fr
Tue Nov 26 10:15:15 EST 2002
At last we got some results but we got this message. Not quite sure what the libref at libref(*)_line.shp corresponds to. Can anybody help on this?
C:\>ogr2ogr polbnda.shp gltp:/vrf/v0soa/vmaplv0/soamafr
ERROR 4: Failed to open Shapefile `libref at libref(*)_line.shp'.
ERROR 1: Terminating translation prematurely after failed
translation of layer libref at libref(*)_line
Emmanuelle <bultee at yahoo.fr> wrote:
Hi Frank,
There was some problem to use the ogr2ogr under windows. The command was unable to find the datasource [Unable to open datasource ] :-( joined the commands below.
I am also not quite sure how can I make sure that the dbf file contains certain columns- such as code ISO, country names, region names.
.\v0soa\vmaplv0\soamafr is the relative path of the data sources
soamer is at the same level as dht. and lat. files
T:\Projects\Analytix\02 Utils\Nima>ogr2ogr -f "ESRI Shapefile" polbnda.shp .\v0s
oa\vmaplv0\soamafr
FAILURE:
Unable to open datasource `.\v0soa\vmaplv0\soamafr' with the following drivers.
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> IHO S-57 (ENC)
-> MapInfo File
-> DGN
-> GML
-> AVCBin
-> OGDI
-> FMEObjects Gateway
Many thanks
Emmanuelle
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Saturday, November 23, 2002 11:32 AM
To: woodbri at swoodbridge.com
Cc: Mapserver-Users
Subject: Re: [mapserver-users] vmap0 to shape file
woodbri at swoodbridge.com wrote:
> OK, I tried this, if you don't have the xvt libraries and includes it
> will not be easy and will only be fun if you like pain and headaches.
> Frank,
> Does ogr2ogr support converting VPF to shapefiles?
> What is the command syntax?
> What are the limits on conversion?
Steve,
Yes, ogr2ogr can be used to translate VPF to shapefile, if you have a
build with OGDI support (such as the OpenEV_FW binary builds). For
instance, to extract the political boundaries you might do this:
warmerda at gdal[589]% ogr2ogr polbnda.shp
gltp:/vrf/usr4/mpp1/v0noa/vmaplv0/noamer
'polbnda at bnd(*)_area'
warmerda at gdal[590]% ls -l polbnda*
-rw-r--r-- 1 warmerda users 1052287 Nov 22 11:58 polbnda.dbf
-rw-r--r-- 1 warmerda users 327 Nov 22 11:57 polbnda.prj
-rw-r--r-- 1 warmerda users 10335532 Nov 22 11:58 polbnda.shp
-rw-r--r-- 1 warmerda users 85980 Nov 22 11:58 polbnda.shx
In the dataset name 'gltp:/vrf/usr4/mpp1/v0noa/vmaplv0/noamer' the
gltp:/vrf part is not really in the filesystem. The VPF data was at
/usr4/mpp1/v0noa. The "noamer" directory should be at the same level as
the dht. and lat. files.
The resulting political boundaries seem to include a "nam" attribute
with the state names/province names. Not too sure about namtional level
boundaries. I couldn't browse around in the data very easily since it
was still fairly large.
The limits? I'm not too sure what issues you will run into. The data
model is VPF as exposed through the OGDI VPF (vrf) driver.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
Yahoo! Mail -- Une adresse @yahoo.fr gratuite et en français !
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021126/1da603dd/attachment.html
