[mapserver-users] French characters in a map file
Daniel Morissette
morissette at dmsolutions.ca
Tue Nov 26 13:03:41 EST 2002
That's because GD's default fonts encoding is not ISOLatin1... i.e. it
doesn't match the character set used by default on Windows.
You have a few options:
1- Recompile GD with new ISO-8859-1 encoded bitmap fonts... I did that a
while ago for another application. I could provide you with the
modified GD source for that if you want to compile it yourself.
2- Use a TTF font in your GIF legend.
3- Use the HTML legend, then the French characters will be rendered in
HTML.
Daniel
Debbie Pagurek wrote:
> Hi everyone,
> I am trying to translate one of my applications into French and I am running into problems with French characters in my mapfile, and the legend generation.
> see this excerpt from my mapfile layer:
> CLASS
> EXPRESSION '0' #dummy class for title
> NAME 'Écozones'
> COLOR 255 255 255
> OUTLINECOLOR 255 255 255
> END # CLASS
> CLASS
> EXPRESSION '1'
> NAME 'Cordillère arctique'
> COLOR 204 255 255
> END # CLASS
> The first class name Écozones appears properly in my legend, but the second one, Cordillère arctique, does not. Please see the attached image of the resulting legend.
> So... does anyone know how to get French accents to appear properly in a legend??
> Thanks,
> D. Pagurek
> legenderr.gif Type: GIF Image (image/gif)
> Encoding: base64
