[mapserver-users] Query from a text string
Ben Stewart
stewartjb at agr.gc.ca
Wed Nov 27 07:51:19 EST 2002
Hello:
I am building a prototype for an application which highlights a polygon on a map, then downloads data from a remote URL. The user clicks the map, and a download box pops up with the highlighted polygon on the map behind it.
The query is very straight forward. The querymap displays, and a function retrieves the polygon label, in a CGI variable from the shapefile. It uses java script to download an indexed dbase file with the same name as the label, from a remote URL.
As a final step, I now want to take input from a text box and achieve the same functionality as I do when clicking on the map. Retrieving the ZIP file, is no problem, but as yet I am not able to bring up the query map. Can anyone suggest on how I might go about doing this? I notice that in a query string, the coordinates of a mouse click are usually passed to mapserver. If I'm querying from a text string, I can't provide the coordinates of a click. I can only provide the label, which as I mentioned is an attribute for that polygon.
Template and Mapfile are provided below if it would help you to look at them, but I am just looking for some direction.
Thank you, very much for your assistance.
<-----MAPFILE------------------------------------------------------------>
#Start of Map File - "core.map"
MAP
Name test
Status on
Size 240 165
Extent -2700000 -1175000 3500000 4500000
Units meters
Shapepath "data"
Symbolset symset.sym
Fontset "/usr/www/httpd/htdocs/mapdata/style/fonts.txt"
WEB
TEMPLATE test.html
IMAGEPATH "/usr/www/httpd/htdocs/mapdata/tmp/"
IMAGEURL "/mapdata/tmp/"
END # web
QUERYMAP
SIZE 240 165
STATUS ON
STYLE HILITE
COLOR 255 255 0
END #QUERYMAP
# Start of Layer Definitions
LAYER
NAME mapsheet
TYPE polygon
STATUS default
DATA "cliiwms"
TEMPLATE test.html
#TEMPLATE "http://sis.agr.gc.ca/cansis/nsdb/cli/cai[SHEET].zip"
CLASSITEM 'cli_ag'
CLASS
NAME mapsheet
EXPRESSION ([cli_ag] = 1)
COLOR 255 255 204
OUTLINECOLOR 000 000 000
END #CLASS
END #LAYER
LAYER #Display labels at a specific resolution
NAME mapsheetlabels
TYPE polygon
STATUS default
DATA "cliiwms"
MINSCALE 500000
MAXSCALE 12000000
TEMPLATE test.html
LABELITEM "sheet"
CLASSITEM 'mapsheet'
CLASS
NAME 'mapsheet'
Expression ([cli_ag] = 1)
# COLOR 255 255 204
# OUTLINECOLOR 0 0 0
LABEL
COLOR 66 33 0
SIZE small
FORCE on
END #LABEL
END #CLASS
END # layer
LAYER
NAME themap
TYPE line
STATUS default
DATA "cliwmsp"
CLASS
NAME 'details'
COLOR 0 0 0
OUTLINECOLOR 0 0 0
END #CLASS
END # layer
LAYER
NAME cities
TYPE point
STATUS default
DATA "citieswms"
MINSCALE 500000
MAXSCALE 12000000
LABELITEM "Name"
CLASSITEM 'name'
CLASS
NAME 'City'
SYMBOL "circle"
SIZE 5
COLOR 250 0 0
LABEL
COLOR 0 0 255
SIZE small
OFFSET 5 5
POSITION auto
END # label
END # class
END # layer
END #MAPFILE
<--------TEMPLATE------------------------------------------------------>
<html>
<head><title>Text Strings and Queries</title>
<Script language = "JavaScript">
function textquery(){ called from the form
var sheet=document.theform.searchbox.value;
window.location.href="http://sis.agr.gc.ca/cansis/nsdb/cli/cai"+sheet+".zip";
function checkquery() { onLoad from body tag
var test = "[SHEET]";
if (test.length > 0) {
if (test.length < 5)
window.location.href = "http://res.agr.ca/CANSIS/NSDB/CLI/cai[SHEET].zip";
</script>
</head>
<body onLoad="checkquery()">
<center>
<br><br>
<B>
My Little Text String Query
</B>
<br><br>
<form name="theform" method=GET action="/cgi-bin/mapserver/mapserv"
onSubmit="textquery()">
<center>
<table border=0 cellspacing=0 cellpadding=4 bgcolor="#cccccc">
<tr><td valign="top">
<input type="image" name="img" SRC="[img]" width=240 height=165 border=0><br>
<input type="radio" name="mode" value="query">QUERY<br>
<input type="radio" name="mode" value="browse" checked>BROWSE<br>
<input type="text" name="searchbox">
<input type="submit" value="gutcha">
<input type="hidden" name="imgxy" value="120 83">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="mapext" value="shapes">
<input type="hidden" name="zoomdir" value="1">
<input type="hidden" name="zoomsize" value="2">
</form>
</td></tr>
</table>
</center>
</body>
</html>
