Betr.: [mapserver-users] Query from a text string
Emil Zegers
EZS at destraat.nl
Wed Nov 27 09:06:25 EST 2002
Hello Ben,
This is only a workaround, not a real solution but maybe worth to give
a try:
Create an extra file (dbf, table in your db) or field in your shapefile
dbf containing the centerpoints of the polygons, query this file with
the label and use the output to create the request to send to
mapserver.
Disadvantages:
- points have to be updated separately when shapefile changes
- points have to be in the polygon so manually editing of centerpoints
might be required (or just use a script that creates a point in a
polygon)
- labels have to be unique
Best regards,
Emil Zegers
>>> "Ben Stewart" <stewartjb at agr.gc.ca> 11/27 1:51 >>>
Hello:
I am building a prototype for an application which highlights a polygon
on a map, then downloads data from a remote URL. The user clicks the
map, and a download box pops up with the highlighted polygon on the map
behind it.
The query is very straight forward. The querymap displays, and a
function retrieves the polygon label, in a CGI variable from the
shapefile. It uses java script to download an indexed dbase file with
the same name as the label, from a remote URL.
As a final step, I now want to take input from a text box and achieve
the same functionality as I do when clicking on the map. Retrieving
the ZIP file, is no problem, but as yet I am not able to bring up the
query map. Can anyone suggest on how I might go about doing this? I
notice that in a query string, the coordinates of a mouse click are
usually passed to mapserver. If I'm querying from a text string, I
can't provide the coordinates of a click. I can only provide the label,
which as I mentioned is an attribute for that polygon.
Template and Mapfile are provided below if it would help you to look at
them, but I am just looking for some direction.
Thank you, very much for your assistance.
<-----MAPFILE------------------------------------------------------------>
#Start of Map File - "core.map"
MAP
Name test
Status on
Size 240 165
Extent -2700000 -1175000 3500000 4500000
Units meters
Shapepath "data"
Symbolset symset.sym
Fontset "/usr/www/httpd/htdocs/mapdata/style/fonts.txt"
WEB
TEMPLATE test.html
IMAGEPATH "/usr/www/httpd/htdocs/mapdata/tmp/"
IMAGEURL "/mapdata/tmp/"
END # web
QUERYMAP
SIZE 240 165
STATUS ON
STYLE HILITE
COLOR 255 255 0
END #QUERYMAP
# Start of Layer Definitions
LAYER
NAME mapsheet
TYPE polygon
STATUS default
DATA "cliiwms"
TEMPLATE test.html
#TEMPLATE "http://sis.agr.gc.ca/cansis/nsdb/cli/cai[SHEET].zip"
CLASSITEM 'cli_ag'
CLASS
NAME mapsheet
EXPRESSION ([cli_ag] = 1)
COLOR 255 255 204
OUTLINECOLOR 000 000 000
END #CLASS
END #LAYER
LAYER #Display labels at a specific resolution
NAME mapsheetlabels
TYPE polygon
STATUS default
DATA "cliiwms"
MINSCALE 500000
MAXSCALE 12000000
TEMPLATE test.html
LABELITEM "sheet"
CLASSITEM 'mapsheet'
CLASS
NAME 'mapsheet'
Expression ([cli_ag] = 1)
# COLOR 255 255 204
# OUTLINECOLOR 0 0 0
LABEL
COLOR 66 33 0
SIZE small
FORCE on
END #LABEL
END #CLASS
END # layer
LAYER
NAME themap
TYPE line
STATUS default
DATA "cliwmsp"
CLASS
NAME 'details'
COLOR 0 0 0
OUTLINECOLOR 0 0 0
END #CLASS
END # layer
LAYER
NAME cities
TYPE point
STATUS default
DATA "citieswms"
MINSCALE 500000
MAXSCALE 12000000
LABELITEM "Name"
CLASSITEM 'name'
CLASS
NAME 'City'
SYMBOL "circle"
SIZE 5
COLOR 250 0 0
LABEL
COLOR 0 0 255
SIZE small
OFFSET 5 5
POSITION auto
END # label
END # class
END # layer
END #MAPFILE
<--------TEMPLATE------------------------------------------------------>
<html>
<head><title>Text Strings and Queries</title>
<Script language = "JavaScript">
function textquery(){
called from the form
var sheet=document.theform.searchbox.value;
window.location.href="http://sis.agr.gc.ca/cansis/nsdb/cli/cai"+sheet+".zip";
function checkquery() {
onLoad from body tag
var test = "[SHEET]";
if (test.length > 0) {
if (test.length < 5)
window.location.href =
"http://res.agr.ca/CANSIS/NSDB/CLI/cai[SHEET].zip";
</script>
</head>
<body onLoad="checkquery()">
<center>
<br><br>
<B>
My Little Text String Query
</B>
<br><br>
<form name="theform" method=GET action="/cgi-bin/mapserver/mapserv"
onSubmit="textquery()">
<center>
<table border=0 cellspacing=0 cellpadding=4 bgcolor="#cccccc">
<tr><td valign="top">
<input type="image" name="img" SRC="[img]" width=240 height=165
border=0><br>
<input type="radio" name="mode" value="query">QUERY<br>
<input type="radio" name="mode" value="browse" checked>BROWSE<br>
<input type="text" name="searchbox">
<input type="submit" value="gutcha">
<input type="hidden" name="imgxy" value="120 83">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="mapext" value="shapes">
<input type="hidden" name="zoomdir" value="1">
<input type="hidden" name="zoomsize" value="2">
</form>
</td></tr>
</table>
</center>
</body>
</html>
__________
VChecked
______________________________________________________
This message has been checked for all known viruses
