[mapserver-users] Itemnquerymap and templates
GAIA
mapserver at peligroso.gaiaenv.com
Thu Nov 28 18:55:16 EST 2002
Hi all,
Probably a simple one, but I am having difficulties finding anything in the docs or in the archives of this list (that works).
I can successfully execute an itemnquerymap and have it return a map, but it does not get rendered into an html template. My preliminary investigation found http://maps.dnr.state.mn.us/mapserver_demos/tests/itemquery/test.html as an example of using itemquerymaps. The only difference between the syntax posted there and what I use is that the demo contains a QUERY object...which occurs inside a LAYER object. In my build of 3.6.3 this seems to return an error loadLayer(): Unknown identifier. (QUERY): Has this changed in 3.6.3 or am I missing something simple?
Would someone please steer me to docs or provide the key components required to apply a template to an itemnquerymap. Thanks in advance.
Cheers,
Jim
