[mapserver-users] php mapscript newbie
Hankley, Chip
Chip.Hankley at gasai.com
Fri Nov 29 09:23:37 EST 2002
Mark... if IE (or any other browser) is spitting out the actual PHP code
(without some statement that says 'Error' or the like) - then the PHP is not
being parsed, and the web server is serving it up to the client (your
browser) as if it were text to display. Make sure that PHP is functioning
correctly first...
something simple like:
<H1>My name is <?echo "Mark";?></H2>
should simply print "My name is Mark"... if you get anything else, PHP isn't
working. At first glance, what you have (MapScript) looks OK.
Chip
-----Original Message-----
From: Mark Balman [mailto:Mark.Balman at birdlife.org.uk]
Sent: Friday, November 29, 2002 4:23 AM
To: 'mapserver-users at lists.gis.umn.edu'
Subject: [mapserver-users] php mapscript newbie
Hi All
I have sucessfully created a simple app using mapserver and polished this up
using Maplab. I am now wanting to enhance the functionality using php
mapscript. I have read the PHP/Mapscript by example HOWTO document and have
tried unsuccesfully to get a simple world map to display.
I have tried the following (using Win98, Apache, mapserver 3.6)
------------------mapfile----------------------------------
MAP
SIZE 600 300
STATUS ON
SYMBOLSET ./symbols/symbols.sym
EXTENT -180 -90 180 90
UNITS DD
SHAPEPATH "./data"
NAME test
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
LAYER
NAME world
TYPE POLYGON
STATUS ON
DATA world
CLASS
COLOR 110 50 100
OUTLINECOLOR 200 200 200
END
END
END
-------------phpmapscript-------------------------------
<?php
dl('php_mapscript.dll');
$map_path="/world/";
$map = ms_newMapObj($map_path."test.map");
$image=$map->draw();
$image_url=$image->saveWebImage(MS_PNG,1,1,0);
<HTML>
<HEAD>
<TITLE>Example 1: Displaying a map</TITLE>
</HEAD>
<BODY>
<IMG SRC=<?php echo $image_url; ?> >
</BODY>
</HTML>
When I try and open the file I get the following displayed in IE4 :(
draw(); $image_url=$image->saveWebImage(MS_GIF,1,1,0); ?> >
Can anyone enlighten me as to what I am doing wrong?
Thanks in advance
Mark
