SV: [mapserver-users] Oracle spatial support
Bjarni Pjetursson
Bjarni.Pjetursson at tietoenator.com
Wed Oct 2 10:07:32 EDT 2002
Hi Fabio,
at our company we have been using mapserver for some time to map fishing
vessels at sea using Oracle Locator (Oracle Spatial light).
Maybe you can use our mapserver compile:
MapServer version 3.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=JPEG INPUT=ORACLESPATIAL
INPUT=OGR INPUT=SHAPEFILE
You should however be aware of some current limitations in the Oracle
Spatial support:
1. You can only work on one column in your layer besides the spatial column.
2. You can not use the query-object feature.
Get our exe-file from here:
http://www.enator.dk/mapserv/mapserv361spatial.htm
(this link will only be available for a short while)
Regards
Bjarni Thor Pjetursson
TietoEnator Consulting A/S
Denmark
> -----Oprindelig meddelelse-----
> Fra: Fabio Corsi [SMTP:f.corsi at pan.bio.uniroma1.it]
> Sendt: 27. september 2002 22:50
> Til: mapserver-users at lists.gis.umn.edu
> Emne: [mapserver-users] Oracle spatial support
> Hi,
> I have been using Mapserver successfully for a few months using shape
> files. Now I would like to mode my data into an Oracle server with SDO and
> use Mapserver to browse the data.
> The only version of Mapserver I could find with oraclespatial enabled is
> the one at <http://parvillers.homeip.net/mapserver/> (and it is ver. 3.5).
> I was wondering whether there is precompiled win32 version of Mapserver
> 3.6.1 with oraclespatial available. I would also appreciate directions to
> examples, tutorials and/or documentation on how to use Mapserver with
> Oracle Spatial.
> Many thanks,
> Fabio
> Fabio Corsi
> Istituto di Ecologia Applicata
> Via L.Spallanzani, 32
> 00161 Roma, ITALIA
> phone & fax +39 06 4403315
> f.corsi at pan.bio.uniroma1.it <mailto:f.corsi at pan.bio.uniroma1.it>
> f.corsi at ieaitaly.org <mailto:f.corsi at ieaitaly.org>
