[mapserver-users] RE: Mapserver Question...
Mackey Timothy
Timothy.Mackey at ga.gov.au
Wed Oct 2 23:21:08 EDT 2002
Hi Heath,
I've looked at your application and have a suggestion:
The first line of your form in the central frame is
<input type="hidden" name="mode" value="browse">
You therefore need to make sure that you reset this value in querycheck()
document.mainmap.mode.value="nquery";
*before* you submit the form.
As this is all in the one frame, it's not an issue of frames vs no frames, it's just a matter of getting the javascript working.
regards,
Tim Mackey
Webmaster
Geoscience Australia
timothy.mackey at ga.gov.au
http://www.ga.gov.au
-----Original Message-----
From: Clint Heath [mailto:heathcd at cnrit.tamu.edu]
Sent: Thursday, 3 October 2002 12:03
To: wizard at auslig.gov.au
Subject: Mapserver Question...
Hello,
I'm hoping that I can ask a question of Tim Mackey or any other
Mapserver gurus you have there. I'm developing a web page using Frames
and Mapserver just like you've got here on your site, but I'm having a
problem with the query function working in a frames web page. I get no
results. If I take my .map file and put it into a flat HTML page, I can
query the layers just fine, but they don't return anything in my
frames-based page. My question is, did you have to overcome any similar
problems when you set up your page? Are there some key things I should
know about how to get querying working in a frames/Mapserver page? I'm
using Mapserver 3.6.1 and here's my URL if you care to look:
http://cnrit.tamu.edu/maps/map_init.html
Click on the very last button, the one that says "FRAMES VERSION" on it.
Thank you in advance for any advice you can offer.
Clint Heath
Systems Analyst
Texas A&M University
