[mapserver-users] Antialiased Lines in mapserver?
Lowell Filak
lfilak at medinaco.org
Thu Oct 3 10:56:22 EDT 2002
While it's not antialiasing you could play with different colors and sizes for symbol & overlaysymbol which may help the lines to visually blur.
Lowell F.
The following message was sent by David Monterroso Cabello <pyro-x at ixine.com> on Thu, 03 Oct 2002 13:22:06 +0200.
> Hi there!
> I'm developing a *streetmap* application using mapserver, and
> although i like the output i get, it still looks bad cause those jagged
> lines. Is there any way to have antialiased lines in mapserver?, i saw
> in some old posts that it was a GD matter, and that even in 2.0 versions
> it still doesn't support antialias. Does somebody know if there is
> another way to do antialiasing?. I tried to render a double sized image
> and then reduced it with ImageMagick but the results were awful.
> And finally, a question for developers, would it be possible to
> switch to ImageMagick for vector rendering?, that library render fine
> antialiased lines =), althought i dunno if it support everything
> mapserver needs.
> Many thanx
> David Monterroso Cabelo
