[mapserver-users] TRUETYPE SUPPORT
Tyler Mitchell
TMitchell at lignum.com
Fri Oct 4 11:34:04 EDT 2002
AFAIK - it works. You need to set a few things in your mapfile, can you
send yours to me? Here's the items:
FONTSET xxxxxx - near the top of the map file points to a text file that
lists the font name and points it to a ttf file.
I set mine like this:
FONTSET "fontsets\fonts.txt"
I'll attach my fonts.txt file for you. I also copy the ttf files into my
fontsets folder.(See attached file: fonts.txt)
In a label object set:
TYPE TRUETYPE
And then FONT xxxxxx - based on the first column in the fonts.txt file -
i.e. arial
I chunk of my map file looks like this
LAYER
CLASS
LABEL
FONT arialbold
TYPE truetype
ANTIALIAS TRUE
POSITION AUTO
COLOR 255 0 0
OUTLINECOLOR 255 255 255
PARTIALS FALSE
SIZE 8
END
END
END
Does that help you out?
Toni Hernández
<toni at giscampus.udg.es> To: <mapserver-users at lists.gis.umn.edu>
Sent by: cc:
owner-mapserver-users at lists. Fax to:
gis.umn.edu Subject: [mapserver-users] TRUETYPE SUPPORT
10/04/2002 04:27 AM
hi everyone,
Does anyone know if the last 3.6.1 version for windows has TRUETYPE
support?
I don't think so because I get the error "Requested font (arial) not found.
If it doesn't where can I find one version with TRUTYPE support?
Thanks for your time and knowledge
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021004/830d1945/iso-8859-1Qfonts.obj
