[mapserver-users] PostGIS performance
Alexander Pucher
pucher at atlas.gis.univie.ac.at
Mon Oct 7 08:47:30 EDT 2002
Hi Jan,
everytime I read one of your mails I think yes, yes, this must be
it...but still no success ;-(
Jan Hartmann wrote:
> Hello Alex,
> Try the inner select from a terminal (select nut3. ...). This should
> give back records with three fields, so you can check whether your
> selection criteria are right. If I read the description of your data
> right I would say that the where-statement would have to be:
> where nut3.nurgcd = un3rt.nurgcd
Sorry my fault: the correct version _is_ where nut3.nurgcd = un3rt.geo
so the line in the DATA statement is correct.
The inner selecion works fine with three fields, the_geom, oid and
myclass. Also the complete query works fine from a terminal, as I told
already.
> However, if your original line is right and you get back records for
> all classes with the interactive select, something is wrong with the
> MapServer interface. Try quoting the SQL case statements:
> case when ... then "1"
Tried it out with no success. It' funny that when I remove all but the
first class and comment out the EXPRESSION line like this,
CLASS
# EXPRESSION "1"
COLOR 255 0 0
END
it should draw all polygons in red, but still it doesn't. It seems to
ignore the whole layer!!
Is there something wrong with my EXPRESSIONs? I even tried it with 'one'
instead of '1' and changed the regex to /one/ . Also tried '1' and
([myclass] = 1)
Is there something stupid missing in my LAYERs section of the mapfile?
Regards,
alex
# Start of layer definitions
LAYER
NAME "nut3"
STATUS ON
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "user=xxxx password=xxxx dbname=xxxx host=localhost"
DATA "the_geom from (select nut3.the_geom,nut3.oid,case when
un3rt.unit > 16 then '1' when un3rt.unit between 10 and 16 then '2' when
un3rt.unit between 5 and 10 then '3' when un3rt.unit between 0 and 5
then '4' else '5' end as myclass from nut3,un3rt where
nut3.nurgcd=un3rt.geo) as foo"
METADATA
"DESCRIPTION" "NUTS3 Area polygons"
END #METADATA
CLASSITEM "myclass"
CLASS
EXPRESSION "1"
COLOR 255 0 0
END
CLASS
EXPRESSION "2"
COLOR 250 100 100
END
CLASS
EXPRESSION "3"
COLOR 250 200 200
END
CLASS
EXPRESSION "4"
COLOR 250 220 220
END
CLASS
EXPRESSION "5"
COLOR 210 210 210
END
END #LAYER
LAYER
NAME "nut3lin"
STATUS ON
DATA "the_geom from nut3_arc"
#DESCRIPTION "nut3lin"
TYPE LINE
CONNECTION "user=pucher password=mapserver dbname=geodb host=localhost"
METADATA
"DESCRIPTION" "NUTS3 boundaries lines"
END #MEATDATA
CLASS
#NAME "Nuts3 Gebiete"
COLOR 0 0 0
END #CLASS
END #LAYER
END #MAP
> Perhaps this solves it, although I thought you could pass number
> values unquoted.
> Jan
________________________________________________________
Institut fuer Geographie und Regionalforschung
Universitaet Wien
Kartografie und Geoinformation
Departement of Geography and Regional Research
University of Vienna
Cartography and GIS
Universitaetstr. 7, A-1010 Wien, AUSTRIA
Tel: (+43 1) 4277 48644
Fax: (+43 1) 4277 48649
E-mail: alexander.pucher at univie.ac.at
FTP: ftp://ftp.gis.univie.ac.at
WWW: http://www.gis.univie.ac.at/karto
Atlas of Eastern and Southeastern Europe: http://www.aos.ac.at
M$ is not the answer. M$ is the question!
No is the answer -- Eric Naggum
