[mapserver-users] PostGIS performance
Jan Hartmann
jhart at frw.uva.nl
Mon Oct 7 11:51:12 EDT 2002
Your mapfile looks good and I double-checked my own mapfiles, so this is
the right way. However, are you using MapServer CGI? In that case you
have to set "STATUS DEFAULT" in the layer section; "STATUS ON" leaves
the layer invisible. This really should be put somewhere in the docs
with extra big capitals. -:)
Jan
Alexander Pucher wrote:
> Hi Jan,
> everytime I read one of your mails I think yes, yes, this must be
> it...but still no success ;-(
> Jan Hartmann wrote:
>> Hello Alex,
>> Try the inner select from a terminal (select nut3. ...). This should
>> give back records with three fields, so you can check whether your
>> selection criteria are right. If I read the description of your data
>> right I would say that the where-statement would have to be:
>> where nut3.nurgcd = un3rt.nurgcd
> Sorry my fault: the correct version _is_ where nut3.nurgcd = un3rt.geo
> so the line in the DATA statement is correct.
> The inner selecion works fine with three fields, the_geom, oid and
> myclass. Also the complete query works fine from a terminal, as I told
> already.
>> However, if your original line is right and you get back records for
>> all classes with the interactive select, something is wrong with the
>> MapServer interface. Try quoting the SQL case statements:
>> case when ... then "1"
> Tried it out with no success. It' funny that when I remove all but the
> first class and comment out the EXPRESSION line like this,
> CLASS
> # EXPRESSION "1"
> COLOR 255 0 0
> END
> it should draw all polygons in red, but still it doesn't. It seems to
> ignore the whole layer!!
> Is there something wrong with my EXPRESSIONs? I even tried it with 'one'
> instead of '1' and changed the regex to /one/ . Also tried '1' and
> ([myclass] = 1)
> Is there something stupid missing in my LAYERs section of the mapfile?
> Regards,
> alex
> # Start of layer definitions
> LAYER
> NAME "nut3"
> STATUS ON
> TYPE POLYGON
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=xxxx password=xxxx dbname=xxxx host=localhost"
> DATA "the_geom from (select nut3.the_geom,nut3.oid,case when
> un3rt.unit > 16 then '1' when un3rt.unit between 10 and 16 then '2' when
> un3rt.unit between 5 and 10 then '3' when un3rt.unit between 0 and 5
> then '4' else '5' end as myclass from nut3,un3rt where
> nut3.nurgcd=un3rt.geo) as foo"
> METADATA
> "DESCRIPTION" "NUTS3 Area polygons"
> END #METADATA
> CLASSITEM "myclass"
> CLASS
> EXPRESSION "1"
> COLOR 255 0 0
> END
> CLASS
> EXPRESSION "2"
> COLOR 250 100 100
> END
> CLASS
> EXPRESSION "3"
> COLOR 250 200 200
> END
> CLASS
> EXPRESSION "4"
> COLOR 250 220 220
> END
> CLASS
> EXPRESSION "5"
> COLOR 210 210 210
> END
> END #LAYER
> LAYER
> NAME "nut3lin"
> STATUS ON
> DATA "the_geom from nut3_arc"
> #DESCRIPTION "nut3lin"
> TYPE LINE
> CONNECTION "user=pucher password=mapserver dbname=geodb host=localhost"
> METADATA
> "DESCRIPTION" "NUTS3 boundaries lines"
> END #MEATDATA
> CLASS
> #NAME "Nuts3 Gebiete"
> COLOR 0 0 0
> END #CLASS
> END #LAYER
> END #MAP
>> Perhaps this solves it, although I thought you could pass number
>> values unquoted.
>> Jan
