[mapserver-users] error building mapserver 3.6.3 on OS X 10.2
Puneet Kishor
pkishor at GeoAnalytics.com
Thu Oct 10 10:36:30 EDT 2002
as a follow-up, I found the following in the archives --
http://mapserver.gis.umn.edu/wilma/mapserver-users/0210/msg00011.html
by Sean Gillies...
> I'm not sure about all your errors, but I recognize
> two of them. You do not say so, but it looks to me
> like you might be trying to compile mapserver using
> gcc 3.x. I've never seen the errors you report
> when building with gcc 2.9.x.
> 1) Remove /usr/local/include from your INCLUDE_DIRS
> so that gcc doesn't complain about it.
> 2) The error
> undefined reference to `__gxx_personality_v0'
> tells you that you need to link shp2img using
> g++ rather than gcc because one of your libraries
> has C++ code.
> If you're not using gcc 3.x, please disregard my
> suggestions.
looking at my errors below, this seems to be a similar problem. I _am_
using gcc 3.1. I have no way of reverting back to an earlier gcc
version. Is this a known problem? Is there a workaround?
Thanks.
pk/
On Wednesday, October 9, 2002, at 11:46 PM, Puneet Kishor wrote:
> while make-ing, the program ends with the following --
> ranlib libmap.a
> ranlib: file: libmap.a(mapthread.o) has no symbols
> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> -DUSE_PROJ_API_H -DUSE_WMS -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG
> -DUSE_GD_WBMP -DUSE_GD_FT -I/usr/local/include
> shp2img.c -o shp2img.o
> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> shp2img.o -L. -lmap -lgd -L/usr/local/lib -lgd -ljpeg
> -L/usr/local/lib -lpng -lz -ljpeg -L/usr/local/lib -lpng -lz -lproj
> -ljpeg -lm -o shp2img
> ld: Undefined symbols:
> ___gxx_personality_v0
> make: *** [shp2img] Error 1
> Then, make install tells me that it
> cp -f libmap.a /usr/local/lib/
> cp -f map.h /usr/local/include/mapserver-3.5/
> strange, that mapserver-3.5/ above. Needless to say, there is no map.h
> under /usr/local/include but there is one under my mapserver-src
> directory where I build everything. So, not knowing any better, I cp
> map.h to /usr/local/include where all other .h files live. Then I try
> to build perl/mapscript but, perl Makefile.pl quits with
> perl Makefile.PL
> Unable to open perlvars, have you built the MapServer yet? at
> Makefile.PL line 4.
> My guess is that the initial make itself failed when shp2img croaked.
> I went through the Makefile and it seems logical that process didn't
> complete at all. What is going on?
> Many thanks,
> Puneet.
