[mapserver-users] 3.6.3 Compile problems/errors
Daniel Morissette
morissette at dmsolutions.ca
Thu Oct 10 11:17:36 EDT 2002
> Steven Bowden wrote:
> Daniel,
> I have got IMAGEPATH and IMAGETMP set in the map file. Here is the
> extract from my map file
> WEB
> LOG /var/www/html/blis/blis.log
> IMAGEPATH "/var/www/html/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> WMS_TITLE "BLIS"
> WMS_ABSTRACT "This is the BLIS (Bundaberg Land Information
> System)."
> WMS_ACCESSCONSTRAINTS none
> END
> END
> I changed the working path (/var/www/html/blis) to writable and it
> then saved the tmp images to this directory even though IMAGEPATH was
> was set to /var/www/html/tmp/ in the map file.
> Any thoughts?
> Steve
This is very odd. Can you check that you don't have a second IMAGEPATH
further down in your mapfile?
Also, try printing the value of $map->web->imagepath immediately after
the call to ms_newMapObj() to find out if it reads the right value.
Then print this value again just before the call to SaveWebImage() ...
if the value is empty before saveWebImage() then it must be your script
that changed the value somewhere. If the value is still valid then it
is likely a bug in MapScript and the best way to troubleshoot this for
us would be to get a small sample app with scripts and data that
reproduces this. But since nobody else ran into that, it seems unlikely
to be a bug and I would check for a problem in the mapfile or PHP script
first.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
