[mapserver-users] msQueryByAttributes(): Search returned no r
esults. No matching re cord(s) found.
KRUSEMARK Matthew G
matthew.g.krusemark at co.multnomah.or.us
Thu Oct 10 11:32:51 EDT 2002
Just wanted to send a big thanks to Robert Stanton, Anwar Hussain, Gunter
Rieth, Perry Nacionales and Steve Lime for helping me understand the FILTER
and FILTERITEM params in 3.6.
Kind regards,-matthew
-----Original Message-----
From: Robert Stanton [mailto:geosys at iafrica.com]
Sent: Thursday, October 10, 2002 2:51 AM
To: KRUSEMARK Matthew G
Subject: Re: [mapserver-users] msQueryByAttributes(): Search returned no
results. No matching re cord(s) found.
Hi Matthew
In your 'FILTER "%cty_name%" ' statement I believe you are passing the dbf
column name to mapserver where you should be passing the value in a field in
that column.
In my map file I have:
FILTERITEM "cty_name"
FILTER "%value%"
and I then pass the %value% to mapserver either by:
<input type="hidden" name="item" value="cty_name">
<input type="hidden" name="value"
value="actual_value_in_the_required_field">
in the html file, or:
&item=cty_name&value=actual_value_in_the_required_field
in a url, or select the value from a option select list in the html file,
using name="value"
All this had me fooled for a long time until I understood the 'item/value'
parameter passing. I hope this helps.
Regards
Robert Stanton
Durban
South Africa
----- Original Message -----
From: "KRUSEMARK Matthew G" <matthew.g.krusemark at co.multnomah.or.us>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, October 09, 2002 2:00 AM
Subject: [mapserver-users] msQueryByAttributes(): Search returned no
> Hello,
> I am having trouble with ItemQuery in 3.6. My error message is:
> msQueryByAttributes(): Search returned no results. No matching
> record(s) found.
> I have the qlayer set as such:
> <input type="hidden" name="map"
> value="D:\Inetpub\wwwroot\gisshare_web\mapserver_demo36\itasca\case1.m
> ap">
> <input type="hidden" name="qlayer" value="county">
> <input type="hidden" name="mode" value="itemquery">
> ... But may be making mistakes on the syntax of the FILTER and
> FILTERITEM params, I checked the docs and tried a few things, however,
> nothing successful yet. Piece of mapfile:
> LAYER
> NAME county
> DATA county
> STATUS DEFAULT
> TYPE POLYGON
> FILTERITEM cty_name
> FILTER "%cty_name%"
> CLASS
> NAME county
> COLOR 212 212 212
> OUTLINECOLOR 0 0 0
> TEMPLATE case1_template.html
> END
> END
> Thanks in advance for any assistance on this, kind regards,-matthew
