[mapserver-users] error building mapserver 3.6.3 on OS X 10.2
Puneet Kishor
pkishor at GeoAnalytics.com
Thu Oct 10 11:38:32 EDT 2002
On Thursday, October 10, 2002, at 09:45 AM, Zak James wrote:
> With OS X 10.2, the default compiler is now gcc 3.1 which has some
> trouble with mapserver. The easiest way to get around the problem is
> to use the built in gcc_select script. As root, gcc_select 2 will
> switch to the old compiler, which is still available. You can switch
> back by issuing gcc_select 3.
Thanks Zak. Peachy. It all works now. On a related note, do you know
where the problem lies? Is it in Apple's implementation of gcc? Is this
a mapserver-specific problem? or have you encountered it while building
other programs? I only encountered these problems while building
mapserver. Everything else built fine using gcc3.1.
Thanks.
> On Thursday, Oct 10, 2002, at 00:46 America/Montreal, Puneet Kishor
> wrote:
>> while make-ing, the program ends with the following --
>> ranlib libmap.a
>> ranlib: file: libmap.a(mapthread.o) has no symbols
>> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>> -DUSE_PROJ_API_H -DUSE_WMS -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG
>> -DUSE_GD_WBMP -DUSE_GD_FT -I/usr/local/include
>> shp2img.c -o shp2img.o
>> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>> shp2img.o -L. -lmap -lgd -L/usr/local/lib -lgd -ljpeg
>> -L/usr/local/lib -lpng -lz -ljpeg -L/usr/local/lib -lpng -lz -lproj
>> -ljpeg -lm -o shp2img
>> ld: Undefined symbols:
>> ___gxx_personality_v0
>> make: *** [shp2img] Error 1
