[mapserver-users] error building mapserver 3.6.3 on OS X 10.2
Zak James
zak-ms at aiya.dhs.org
Thu Oct 10 12:24:35 EDT 2002
I'm not sure what the problem with gcc 3 is - I think there are
problems with it and mapserver on other platforms too. There is a good
page on OS X porting issues at
http://fink.sourceforge.net/doc/porting/index.php
though they don't mention that specifically. The loadable modules stuff
they discuss does shed some light on building php mapscript.
If you manage to get it to compile with gcc 3, let me know as I'm still
working on an OS X build how-to for mapserver.
zj
On Thursday, Oct 10, 2002, at 11:38 America/Montreal, Puneet Kishor
wrote:
> On Thursday, October 10, 2002, at 09:45 AM, Zak James wrote:
>> With OS X 10.2, the default compiler is now gcc 3.1 which has some
>> trouble with mapserver. The easiest way to get around the problem is
>> to use the built in gcc_select script. As root, gcc_select 2 will
>> switch to the old compiler, which is still available. You can switch
>> back by issuing gcc_select 3.
> Thanks Zak. Peachy. It all works now. On a related note, do you know
> where the problem lies? Is it in Apple's implementation of gcc? Is
> this a mapserver-specific problem? or have you encountered it while
> building other programs? I only encountered these problems while
> building mapserver. Everything else built fine using gcc3.1.
> Thanks.
>> On Thursday, Oct 10, 2002, at 00:46 America/Montreal, Puneet Kishor
>> wrote:
>>> while make-ing, the program ends with the following --
>>> ranlib libmap.a
>>> ranlib: file: libmap.a(mapthread.o) has no symbols
>>> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>> -DUSE_PROJ_API_H -DUSE_WMS -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG
>>> -DUSE_GD_WBMP -DUSE_GD_FT -I/usr/local/include
>>> shp2img.c -o shp2img.o
>>> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>> shp2img.o -L. -lmap -lgd -L/usr/local/lib -lgd -ljpeg
>>> -L/usr/local/lib -lpng -lz -ljpeg -L/usr/local/lib -lpng -lz
>>> -lproj -ljpeg -lm -o shp2img
>>> ld: Undefined symbols:
>>> ___gxx_personality_v0
>>> make: *** [shp2img] Error 1
