[mapserver-users] error building mapserver 3.6.3 on OS X 10.2
Puneet Kishor
pkishor at GeoAnalytics.com
Thu Oct 10 12:45:43 EDT 2002
dunno if you got my most recent message. Seems like I spoke too soon. I
am now getting a load of gd related errors in my Apache log. (you
should soon get that message... the mapserver listserver is kinda slow).
Wrt, OS X build how-to, please consider updating/adding to
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MacOS
that would consolidate all the work.
Many thanks.
Puneet.
On Thursday, October 10, 2002, at 11:24 AM, Zak James wrote:
> I'm not sure what the problem with gcc 3 is - I think there are
> problems with it and mapserver on other platforms too. There is a good
> page on OS X porting issues at
> http://fink.sourceforge.net/doc/porting/index.php
> though they don't mention that specifically. The loadable modules
> stuff they discuss does shed some light on building php mapscript.
> If you manage to get it to compile with gcc 3, let me know as I'm
> still working on an OS X build how-to for mapserver.
> zj
> On Thursday, Oct 10, 2002, at 11:38 America/Montreal, Puneet Kishor
> wrote:
>> On Thursday, October 10, 2002, at 09:45 AM, Zak James wrote:
>>> With OS X 10.2, the default compiler is now gcc 3.1 which has some
>>> trouble with mapserver. The easiest way to get around the problem is
>>> to use the built in gcc_select script. As root, gcc_select 2 will
>>> switch to the old compiler, which is still available. You can switch
>>> back by issuing gcc_select 3.
>> Thanks Zak. Peachy. It all works now. On a related note, do you know
>> where the problem lies? Is it in Apple's implementation of gcc? Is
>> this a mapserver-specific problem? or have you encountered it while
>> building other programs? I only encountered these problems while
>> building mapserver. Everything else built fine using gcc3.1.
>> Thanks.
>>> On Thursday, Oct 10, 2002, at 00:46 America/Montreal, Puneet Kishor
>>> wrote:
>>>> while make-ing, the program ends with the following --
>>>> ranlib libmap.a
>>>> ranlib: file: libmap.a(mapthread.o) has no symbols
>>>> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>>> -DUSE_PROJ_API_H -DUSE_WMS -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG
>>>> -DUSE_GD_WBMP -DUSE_GD_FT -I/usr/local/include
>>>> shp2img.c -o shp2img.o
>>>> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>>> shp2img.o -L. -lmap -lgd -L/usr/local/lib -lgd -ljpeg
>>>> -L/usr/local/lib -lpng -lz -ljpeg -L/usr/local/lib -lpng -lz
>>>> -lproj -ljpeg -lm -o shp2img
>>>> ld: Undefined symbols:
>>>> ___gxx_personality_v0
>>>> make: *** [shp2img] Error 1
