[mapserver-users] error building mapserver 3.6.3 on OS X 10.2
Zak James
zak-ms at aiya.dhs.org
Thu Oct 10 17:36:47 EDT 2002
Make sure that your gd and mapserver were built by the same
compiler/linker as the linking process has changed somewhat. Are you
sure that the right versions are being used by the webserver? I
expected to have to recompile all the supporting libraries but they
seem to work ok since I had stuck with the old 2.x compiler for
mapserver 3.6.3.
Thanks for the tip on the wiki.
zj
On Thursday, Oct 10, 2002, at 12:45 America/Montreal, Puneet Kishor
wrote:
> dunno if you got my most recent message. Seems like I spoke too soon.
> I am now getting a load of gd related errors in my Apache log. (you
> should soon get that message... the mapserver listserver is kinda
> slow).
> Wrt, OS X build how-to, please consider updating/adding to
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MacOS
> that would consolidate all the work.
> Many thanks.
> Puneet.
> On Thursday, October 10, 2002, at 11:24 AM, Zak James wrote:
>> I'm not sure what the problem with gcc 3 is - I think there are
>> problems with it and mapserver on other platforms too. There is a
>> good page on OS X porting issues at
>> http://fink.sourceforge.net/doc/porting/index.php
>> though they don't mention that specifically. The loadable modules
>> stuff they discuss does shed some light on building php mapscript.
>> If you manage to get it to compile with gcc 3, let me know as I'm
>> still working on an OS X build how-to for mapserver.
>> zj
>> On Thursday, Oct 10, 2002, at 11:38 America/Montreal, Puneet Kishor
>> wrote:
>>> On Thursday, October 10, 2002, at 09:45 AM, Zak James wrote:
>>>> With OS X 10.2, the default compiler is now gcc 3.1 which has some
>>>> trouble with mapserver. The easiest way to get around the problem
>>>> is to use the built in gcc_select script. As root, gcc_select 2
>>>> will switch to the old compiler, which is still available. You can
>>>> switch back by issuing gcc_select 3.
>>> Thanks Zak. Peachy. It all works now. On a related note, do you know
>>> where the problem lies? Is it in Apple's implementation of gcc? Is
>>> this a mapserver-specific problem? or have you encountered it while
>>> building other programs? I only encountered these problems while
>>> building mapserver. Everything else built fine using gcc3.1.
>>> Thanks.
>>>> On Thursday, Oct 10, 2002, at 00:46 America/Montreal, Puneet Kishor
>>>> wrote:
>>>>> while make-ing, the program ends with the following --
>>>>> ranlib libmap.a
>>>>> ranlib: file: libmap.a(mapthread.o) has no symbols
>>>>> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>>>> -DUSE_PROJ_API_H -DUSE_WMS -DUSE_JPEG -DUSE_GD_PNG
>>>>> -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
>>>>> -I/usr/local/include shp2img.c -o shp2img.o
>>>>> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
>>>>> -I/usr/local/include shp2img.o -L. -lmap -lgd
>>>>> -L/usr/local/lib -lgd -ljpeg -L/usr/local/lib -lpng -lz -ljpeg
>>>>> -L/usr/local/lib -lpng -lz -lproj -ljpeg -lm -o shp2img
>>>>> ld: Undefined symbols:
>>>>> ___gxx_personality_v0
>>>>> make: *** [shp2img] Error 1
