[mapserver-users] Mapplet
Brian Fischer
bfischer at mpls.houstoneng.com
Thu Oct 10 12:51:02 EDT 2002
The problem is your temp image directory probably is located somewhere
else on your server. Try putting the whole URL to the temp image.
Ex.) <param name='image'
value='http://www.rrbdin.org/tools/mapserv35/temp_mapserv/[img]'>
Or this should work also
<param name='image'
value='http://[host]/tools/mapserv35/temp_mapserv/[img]'>
Hope this helps,
Brian
-----Original Message-----
Sent: Sunday, November 10, 2002 10:50 AM
To: mapserverlist
Subject: [mapserver-users] Mapplet
Dear listers!
I'm trying to run the JS Mapplet in my application (- I know it worked
before I got this new machine).
The problem:
I'm sure the mapplet and mapserver is working properly, because the
tmp-image files are written and there is no error message for the
javascript -- and: I can drag a zoombox and my overview map shows exact
the cut-out I've choosen. Only the map isn't displayed ... Mapserver
doesn't find and display the temp-image, as it does without the mapplet.
I'm sure the fault is somewhere around the
<param name="image" value="http://[host][img]">
as said in the "mapplet.HowTo" definition.
Here is my state-of-the-art:
<applet codebase="/java/mapplet" code="mapplet.class" width="600"
height="400" name="mapplet" MAYSCRIPT>
<param name="image" value="http://smart/[img]">
</applet>
I tried almost everything I can imagine - maybe I just can't see
something obvious - any help would be appreciated!!
-- thanks in advance!!
Cheers,
Till
-- -- -- terrestris jetzt online! www.terrestris.de -- -- --
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Meckenheimer Allee 166 * 53115 Bonn
Tel.: 0228 73 9647 * Fax.: 0228 73 6538
info at terrestris.de * www.terrestris.de
