[mapserver-users] Zoom to extents - NOT
Martin, Daniel
DMartin at erac.com
Mon Oct 21 12:52:56 EDT 2002
Any chance your zoomsize for the form in question is set to 2? If so, set
it to 1 in the zoomall() function.
document.forms[0].zoomsize.value = "1"
-Dan
> -----Original Message-----
> From: Murray, Ross [mailto:rmurray at NRCan.gc.ca]
> Sent: Monday, October 21, 2002 9:05 AM
> To: 'mapserver-users at lists.gis.umn.edu'
> Subject: [mapserver-users] Zoom to extents - NOT
> I am very new to MapServer and would appreciate any words of
> encouragement
> you may provide before I am prematurely old.
> I have a button on my HTML form called "zoomtoextents". There
> are seperate
> buttons allowing the user to zoom in or zoom out to explore
> the image. The
> theory was that at some point they may wish to see the entire
> map again, so
> they should be able to do so by a single click of a button.
> The code I wrote
> was:
> function zoomall() {
> document.forms[0].imgext.value = "[allext]" ;
> document.forms[0].submit();
> where "[allext]" is a constant that holds the bounding
> latitude/longitude
> values of the map area (the value comes from a database and
> is set before
> the mapserv.exe is called).
> Problem:
> No matter how much (or little) the image is zoomed, clicking
> "zoomtoextents" returns an image at exactly half the maximum
> scale. For
> example, when one of my sample maps loads for the first time,
> its extents
> ([allext]) are the bounding lat/long as described above and
> the scale is 1
> to 500000. If I zoom in by any amount then click
> "zoomtoextents" I get a map
> at 1 to 250000.
> Go Figure?
> <<Murray, Ross.vcf>>
