[mapserver-users] Problem with PHP MapScript
Jeff Berry
jeffb at erlandsen.com
Mon Oct 21 10:30:43 EDT 2002
Sure glad to see the list back! With it down as long as it was, it makes
you realize what a great resource this is.
I'm having trouble with getting PHPMapScript running. When I try to run the
Gmap demo for PHPMapScript, I get the following
error...
Warning: MapServer Error in msGetLabelSize(): Could not find/open font in
/alpha/mapserver/gmap/htdocs/gmap75.php3 on line 548
Fatal error: Call to a member function on a non-object in
/alpha/mapserver/gmap/htdocs/gmap75.php3 on line 549
On reviewing the output from 'make', there is a warning when gcc tries to
compile maplabel.c which reads:
maplabel.c: In function 'msInitFontSet':
maplabel.c:120: warning: control reaches end of non-void function
maplabel.c: In function 'msFreeFontSet':
maplabel.c:131: warning: control reaches end of non-void function
I'm running RedHat Linux 7.2 and have Freetype2 installed. I'm not sure how
to fix this. Any help or suggestions would be much appreciated.
Jeff Berry
Erlandsen & Associates
P.O. Box 2029
Chelan, WA 98816
(509) 682-4189
