[mapserver-users] Problem with PHP MapScript
Daniel Morissette
morissette at dmsolutions.ca
Mon Oct 21 14:52:05 EDT 2002
We should fix the compile warnings, but they shouldn't be related to
your problem.
I suspect that the problem is caused by freetype2 (it doesn't like
relative .ttf paths). Try putting absolute font paths for the ttf files
listed in your fontlist file.
Daniel
Jeff Berry wrote:
> Sure glad to see the list back! With it down as long as it was, it makes
> you realize what a great resource this is.
> I'm having trouble with getting PHPMapScript running. When I try to run the
> Gmap demo for PHPMapScript, I get the following
> error...
> Warning: MapServer Error in msGetLabelSize(): Could not find/open font in
> /alpha/mapserver/gmap/htdocs/gmap75.php3 on line 548
> Fatal error: Call to a member function on a non-object in
> /alpha/mapserver/gmap/htdocs/gmap75.php3 on line 549
> On reviewing the output from 'make', there is a warning when gcc tries to
> compile maplabel.c which reads:
> maplabel.c: In function 'msInitFontSet':
> maplabel.c:120: warning: control reaches end of non-void function
> maplabel.c: In function 'msFreeFontSet':
> maplabel.c:131: warning: control reaches end of non-void function
> I'm running RedHat Linux 7.2 and have Freetype2 installed. I'm not sure how
> to fix this. Any help or suggestions would be much appreciated.
> Jeff Berry
> Erlandsen & Associates
> P.O. Box 2029
> Chelan, WA 98816
> (509) 682-4189
> jeffb at erlandsen.com
