[mapserver-users] Rosa and Mozilla
Hankley, Chip
Chip.Hankley at gasai.com
Mon Oct 28 13:54:07 EST 2002
YES! I thought I was going crazy! I'm getting the same problem with Netscape
7 and Mozilla... I think the key here is the Java Plug-in version:
Java(TM) Plug-in: Version 1.4.1_01
Using JRE version 1.4.1_01 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\hankleydw
Proxy Configuration: Browser Proxy Configuration
This function works fine in IE when using the MS VM, but if I switch over to
the one above (the latest Sun JRE), it does exactly what you're saying... it
hangs the browser.
Interestingly, the image DOES get created, it's just not loading it.
To demo the problem, go to:
http://www.gasai.com/gisapps/world/worldview.html
and try to zoom in. My hunch is that if you're using an older JRE, it'll
work fine, but with a newer one, it'll bomb. I'd be interested to know if
this is a windows only phenomenon.
Chip
