[mapserver-users] Rosa and Mozilla
Don Holeman
dholeman1 at cox.net
Mon Oct 28 15:22:39 EST 2002
Using the latest greatest IE 6.0.2600.0000CO with Microsoft (R) VM for Java,
5.0 Release 5.0.0.3805 the demo stalled on the third or fourth drilldown
request generating a java.io.IOException:
www.gasai.com:80//tmp/103583542529481.png as viewed with my java console.
Here is the code it showed in its entirety, hope it helps:
1st
-1
Try as PNG
init
start : Development Version 2001-09-11
SetImageURL /tmp/103583521226121.png
1st
-1
Try as PNG
SetImageURL /tmp/103583522129361.png
1st
-1
Try as PNG
SetImageURL /tmp/103583541828841.png
1st
-1
Try as PNG
SetImageURL /tmp/103583542529481.png
1st
-1
Try as PNG
java.io.IOException: www.gasai.com:80//tmp/103583542529481.png
----- Original Message -----
To: "'Guillaume SUEUR'" <guillaume.sueur at khi2.fr>; "Liste MapServer"
<mapserver-users at lists.gis.umn.edu>; <rosa-users at dmsolutions.ca>
Sent: Monday, October 28, 2002 1:54 PM
Subject: RE: [mapserver-users] Rosa and Mozilla
YES! I thought I was going crazy! I'm getting the same problem with Netscape
7 and Mozilla... I think the key here is the Java Plug-in version:
Java(TM) Plug-in: Version 1.4.1_01
Using JRE version 1.4.1_01 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\hankleydw
Proxy Configuration: Browser Proxy Configuration
This function works fine in IE when using the MS VM, but if I switch over to
the one above (the latest Sun JRE), it does exactly what you're saying... it
hangs the browser.
Interestingly, the image DOES get created, it's just not loading it.
To demo the problem, go to:
http://www.gasai.com/gisapps/world/worldview.html
and try to zoom in. My hunch is that if you're using an older JRE, it'll
work fine, but with a newer one, it'll bomb. I'd be interested to know if
this is a windows only phenomenon.
Chip
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.408 / Virus Database: 230 - Release Date: 10/24/02
