[mapserver-users] PHP mapscript compiling
Daniel Morissette
morissette at dmsolutions.ca
Tue Oct 29 11:45:09 EST 2002
Vincenzo Patruno wrote:
> Then I changed strategy!
> I installed the nightly version, and in this case I compiled everything without any problem.
> The problem is that the system don't create the file php_mapscript.so.
> Also in this case I opened the Makefile under mapscript/php3 and this is the first part of the file
> CC = gcc
> LD = /bin/true
> CFLAGS = -O2 -Wall -DCOMPILE_DL=1 -DPHP4
> RUNPATHS= -L/usr/local/lib -L/lib -L/usr/lpp/apachessl/sorgenti/mapserver_dev
> Any suggestion?
> Thanks in advance
> Vincenzo
I committed a new configure script to the 3.7-dev CVS. Can you please
try it and see if it works better?
If you're not setup with CVS then you can download
http://www2.dmsolutions.ca/tmp/mapserver-configure-37dev-20021029.tar.gz
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
