[mapserver-users] Raster Data and Memory
Frank Warmerdam
warmerdam at pobox.com
Wed Oct 30 17:04:28 EST 2002
Benjamin Wragg wrote:
> Hi guys,
> I was wondering how MapServer handles raster data. I've seen the large
> list of image formats that are supported, but what does MapServer do
> with the images when it loads them up? Does it try and fit the whole
> image into memory? If this is the case, what happens if say the image
> is 2GB and I have 512MB of memory, will it continue to try and load
> the file into memory, causing (on windows) the swap file to be used,
> or will it just not load the file into memory and call the file from
> the disk when needed?
> Thanks,
> Benjamin Wragg
Benjamin,
What happens depends on a number of factors, mostly on what format
driver is being used.
The built-in PNG, and GIF drivers load the whole source image into
memory. The built-in
JPEG and TIFF drivers scan through the image a line or strip at a time
collecting the data
required for the display.
The GDAL driver passes control down to it's internal drivers to handling
loading the desired
subsampled region. Some of these drivers can do so quite efficiently
... for instance from
TIFF view overviews built. At worst most will scan the whole image to
pick out the portions
needed without having to load the whole thing.
In short, be aware of the format and the characteristics of the driver
you are using for large
images. Generally if you want to handle a large image I would suggest
storing it in GeoTIFF
with overviews pre-built. Other approaches (tiling and separate layers
for different resolutions)
can also be appropriate. The RASTER HOWTO should address some of the
performance issues.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
