[mapserver-users] WMS Client?
Daniel Morissette
morissette at dmsolutions.ca
Wed Oct 30 17:19:21 EST 2002
"Van Ulden, Joost" wrote:
> I have some questions about the WMS Client capabilities of MapServer. Is it
> possible to create a map from both local and remote files. It was my
> understanding that this was possible however I have been unsuccessful. I
> get the following error when trying to load a remote layer:
> msDrawRasterLayer(): Unable to access file. chdir()
It is definitely possible to combine local data and WMS layers in a
single mapfile. We do that a lot.
About the error you get, the only reason I can see that would explain it
would be if your mapfile contained an empty SHAPEPATH value, e.g.:
SHAPEPATH ""
If that's the case, then you should either set SHAPEPATH to a valid
value or not set it at all.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
