[mapserver-users] how to find queryresult from external db in the map
Peter Bruijnen
dumper at mailz.nl
Mon Sep 2 14:03:50 EDT 2002
I'm using mapserver (version 3.6) to query a cadastre map. When clicking on a parcel i get (via an asp-script) the users from that parcel. A parcel can have more then one user. Because of this one to many relationship it's not possible to include the users directly in de shape dbf. Otherwise this should be the easiest way i presume. Now the cadastre number selected in the shape is the link to an external access database with that same cadastre number. Al the corresponding records wil be shown (via asp-script).
So far everything works (perfect) ...
But i also want to search the other way around. Select a user from the access database (via another asp-script?) and highlight the corresponding parcels in de cadastre map. How can i do this. I'm quite new with Mapserver so any help is welcome.
Thanks in advance,
Peter Bruijnen
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020902/06f1d484/attachment.html
