[mapserver-users] Mapserver and Spatial Extent
woodbri at swoodbridge.com
Mon Sep 2 19:14:03 EDT 2002
James,
The extents of a shapefile are stored in the file. Use shpdump and
read the first few lines to get the extents.
-Steve
On 30 Aug 2002 at 10:02, James Anderson wrote:
> Hi,
> I need to know more about the EXTENT command in a Mapserver map file. I
> have a shape file layer of Kampala. The shapefile is in WGS 84 projection.
> The center of the Shapefile is lat=32.5747819077374 and
> lon=0.320786584028765 I need to know how to work out the Extent values
> from the lat and lon. My map file looks like this
> NAME EX1
> EXTENT ???? ???? ???? ????
> SIZE 600 600
> SHAPEPATH "C:\Documents and Settings\Steed\My Documents\mapping\kampala\shp"
> PROJECTION
> "proj=longlat"
> "ellps=WGS84"
> "datum=WGS84"
> "no_defs"
> END
> LAYER
> NAME "Kampala"
> DATA kampala
> STATUS DEFAULT
> TYPE LINE
> CLASS
> COLOR 250 175 25
> END # end of class object
> END # end of layer object
> END # end of map file
> If need to work out the values to put in by the ????s. I need some
> formulas. When I put some random values in the extent, the mapserver
> produces an image, yet it is plain white. I believe that this is because I
> have the extent set to where there is no mapping data. I am still very new
> to using this mapserver. I may have other errors in my map file. I need to
> get this mapping to work. Can anyone help ??
> Thanks,
> James.
