[mapserver-users] TRUETYPE not work
woodbri at swoodbridge.com
Mon Sep 2 21:24:38 EDT 2002
William,
Did you get this to work yet? Looks like you need to specify a font
size. There are no defaults for any of this stuff.
-Steve
On 30 Aug 2002 at 16:12, Zhang, William wrote:
> Steve,
> Yes, I have the MapFile Reference document. I did not specify font in my map
> file just for simplifying the test. I thought that some default font would
> be used by mapserver if no font is specified by user. Is this true? Anyway
> now I add font related lines in the map file below. It still does not work.
> NAME alm
> EXTENT -122.0837 37.6683 -122.1104 37.6885
> SIZE 800 600
> SHAPEPATH "C:\Inetpub\wwwroot\itasca\test\tutorial35"
> FONTSET "C:\Inetpub\wwwroot\itasca\test\fonts\fonts.list"
> LAYER
> TYPE LINE
> STATUS DEFAULT
> DATA alm
> LABELITEM "FENAME"
> CLASS
> COLOR 255 0 0
> LABEL
> TYPE TRUETYPE
> ANTIALIAS
> FONT arial
> COLOR 0 0 0
> ANGLE AUTO
> POSITION UC
> END
> END
> END
> END # end of map file
> I have one line in the fonts.list file
> arial arial.ttf
> I also copy the arial.ttf file to the same directory as fonts.list located.
> Do I miss something else?
> Thank you for the help.
> William
> -----Original Message-----
> From: woodbri at swoodbridge.com [mailto:woodbri at swoodbridge.com]
> Sent: Thursday, August 29, 2002 7:32 PM
> To: Zhang, William; mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] TRUETYPE not work
> William,
> Do you have a Map file Reference document?
> You need to look at the LABEL section, you will see that it mentions
> a FONT tag which references an item in a FONTSET. The document will
> also tell you how to set up the FONTSET file which will need to point
> to the the fonts on your system.
> The documentation page can be found off the Mapserver home page.
> -Steve
> On 29 Aug 2002 at 22:04, Zhang, William wrote:
> > Hi,
> > I got error in the map file below. If I comment out TRUETYPE releated
> lines,
> > the map file works. I downloaded the mapserv.exe from Windows Binary
> > Download page, so it should be TRUETYPE enabled. Could somebody give me
> help
> > on this one?
> > NAME alm
> > SIZE 800 600
> > LAYER
> > TYPE LINE
> > STATUS DEFAULT
> > DATA alm
> > LABELITEM "FENAME"
> > CLASS
> > COLOR 255 0 0
> > LABEL
> > TYPE TRUETYPE
> > ANTIALIAS
> > COLOR 0 0 0
> > ANGLE AUTO
> > POSITION UC
> > END
> > END
> > END
> > Thanks,
> > William Zhang
> > Software Engineer
> > C-Cor.net
> > Phone: (925) 251-3019
> > Fax: (925) 467-0600
> > E-Mail: wzhang at c-cor.net
