[mapserver-users] distance search in PLSS
Richard Greenwood
Rich at GreenwoodMap.com
Mon Sep 2 16:59:55 EDT 2002
Puneet, et al,
I followed this thread and I know that Puneets assumption is a regular
and continuous coverage of PLSS, but as a land surveyor, I have to throw
on here. I do not mean to question Puneets application of his algorithm,
but just for the record, I wanted to clarify what the PLSS is and is not.
The PLSS is not, and was never intended to be regular grid anything like
a map projection system. The PLSS is not a mapping system that can be
treated like a UTM or State Plane zone. It is a means for describing and
conveying real property.
Where a mapping system maintains rectangularity throughout a zone, the PLSS
only attempted to maintain rectangularity within a single township, and
even there it is not particularly rectangular. The east line of a township
was to be geodetic north, with the rest of the lines parallel. The west
line, being the east line of the next township, was also geodetic north, so
obviously not parallel with the other lines in the township due to
convergence. Similarly, the east-west lines were adjusted for convergence
every four townships (depending on region) causing large east-west shifts
every 24 miles as you go north or south. (Nearly ½ mile at my latitude, 43N)
In addition to the lack of rectangularity beyond the township, there are an
endless array of other things that preclude a regular coverage, such as
water bodies and senior rights or surveys. Senior rights or surveys
include things like Homestead Entry Surveys, Indian and Military
Reservations, and state lines. Independent resurvey, which are quite common
in some areas of the western states due to fraudulent original surveys,
completely muck up the works.
Sorry if I sound like Im ranting. I dont mean to be critical of anyone.
The PLSS is a truly remarkable system that has served us well for nearly
225 years. I have a great respect for the PLSS, and I am just trying to
share a bit of that.
Rich
At 01:04 AM 9/2/2002 -0500, you wrote:
>I have posted a perl script called plsscalc.pl at the above wiki. Given a
>township, range, section, quarter-section, and a search radius in miles,
>this script will spit out all the quarter-sections within the search
>radius of the origin. Assumes regular and continuous coverage of PLSS.
>Hope this helps someone.
>pk/
>On Thursday, August 29, 2002, at 09:52 AM, Puneet Kishor wrote:
>>Thanks for the advice Ed. I thought of generating a table, but I really
>>want to do this with a script so I can specify the distance. Anyway...
>>all this discussion has got me thinking and I am putting together a Perl
>>script that might be able to do what I want. When I get it working right
>>I will post it here for others.
>Richard W. Greenwood, PLS
>Greenwood Mapping, Inc.
>(307) 733-0203
>http://www.GreenwoodMap.com
