[mapserver-users] question regarding postgis
Tyler Mitchell
TMitchell at lignum.com
Wed Sep 4 12:46:06 EDT 2002
Hi Grant,
The easiest thing to do would be to use the shp2pgsql program which
converts a shapefile into SQL commands to create a layer/table with a
specific name. I will send you a sample shapefile if you would like one.
run "shp2pgsql --help" to see the syntax. You can pipe the output to a
text file and look at it there (i.e. "shp2pgsql myshp.shp newtable testdb >
mysql.sql") or pipe it directly to pgsql to load it into the database (i.e.
"shp2pgsql myshp.shp newtable testdb | pgsql testdb"). Let me know if you
need more help.
Tyler
p.s. you can also use the "ogr2ogr" tool (part of the gdal/ogr package) to
convert other formats directly to postgis.
Grant Marblestone
<GrantM at ATSER.com> To: MapServer List
Sent by: <mapserver-users at lists.gis.umn.edu>
owner-mapserver-users at lists. cc:
gis.umn.edu Fax to:
Subject: [mapserver-users] question regarding postgis
09/04/2002 08:36 AM
Please respond to Grant
Marblestone
Howdy all,
so i have installed postgres 7.2 on my windows box and a linux box... no
big
deal.... now i am thinking about using postgis.
I read thru the documentation and how to add a layer and i understand that
completly. The problem i have is the database structure itself. Can
somoene explain to me what the database has to have in it to create a layer
with x,y,z etc? an example .sql file would eb most excellent.!
Thanks,
Grant
