[mapserver-users] How to keep map from zooming/panning when I
refresh?
Matthew Hatcher
MJHatcher at space.qinetiq.com
Mon Sep 9 03:52:37 EDT 2002
Here is the Javascript function that I use. I think the problem is that the
values for your map click location are kept from the last pan or zoom, so
that when the map refreshes it thinks you have clicked off-centre. (this is
just my laymans interpretation of it, so don't flame me if that's wrong!)
Anyway, this little script works for me:
// update the map without panning or zooming
function updateMap() {
document.mapserv.mode.value = "browse";
document.mapserv.target = "_self";
document.mapserv.zoomdir.value = "0";
document.mapserv.imgext.value = "[minx] [miny] [maxx]
[maxy]";
document.mapserv.imgxy.value = "299.5 215.5";
document.mapserv.submit();
I have attached this function to all the checkboxes I use to turn layers
on/off, so when the user clicks on one it automatically updates, and seems
to work nicely without panning or zooming.
You'll need to change the values in imgxy to reflect your half-image
width/height, and also may need to change the document.mapserv if you've
called your settings form something different.
Good luck!
Matt.
-----Original Message-----
Sent: 06 September 2002 14:53
To: Martin, Daniel
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] How to keep map from zooming/panning when
I refresh?
Thanks for this. This sorta worked...it kept my image from zooming in,
but then it panned to the right for some reason?! I'm not sure what's
up with that, but the other problem is that I've got to keep the
"zoomdir" variable set because I keep the state of my "Zoom In", "Zoom
Out", and "Pan" buttons based on the value of this variable, so setting
it to null resets all my buttons. Regardless of my implementation,
though, I even had this problem with the Itasca Demo... I'm just
wondering if anybody else figured out a way to alter the image without
the Mapserver CGI program reading and executing your zoomdir variable.
Thanks for the help, though...anybody else have any ideas?
MIke
Martin, Daniel wrote:
>Whoops, I messed up the JavaScript. This is a correction, note ".value" is
>added:
>function UpdateMap() {
> document.forms.mapserv.zoomdir.value = "";
>From: Martin, Daniel
>Sent: Thursday, September 05, 2002 11:47 AM
>To: 'Mike Smith'; mapserver-users at lists.gis.umn.edu
>Subject: RE: [mapserver-users] How to keep map from zooming/panning when
>I refresh?
>I think this will work:
> document.forms.mapserv.zoomdir = "";
>Or perhaps I'm missing something. I do exactly what you say in my client,
>but I use Rosa to control zooming and panning, so it is a bit different.
>-Dan
>From: Mike Smith [mailto:nospam at cnrit.tamu.edu]
>Sent: Thursday, September 05, 2002 10:01 AM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [mapserver-users] How to keep map from zooming/panning when I
>refresh?
>Hello,
> I've got my page working pretty well now thanks to lots of
>Javascript code I borrowed from this mailing list, but I've still got
>one problem that I can't seem to find a solution for in the archives.
> I've got my page set up so that the various layers that are available
>to view are in a list on the right-hand side of the page with checkboxes
>next to them. And since I wanted the behavior of the page to imitate
>ArcView as much as possible (because most of my users are used to that
>interface) I put in a little javascript function that automatically
>reloads the page whenever they check or uncheck a layer (without having
>to click a "refresh" button). My problem is that the layer loads or
>unloads fine, but my image also pans or zooms at the same time depending
>on what function they have checked. How can I make my page reload
>without changing the current view at all? Even if they have the "Zoom
>In" button clicked and the zoomsize is set to "2" I don't want the page
>to zoom in when they just add a new layer. Is there a value that I can
>set "zoomdir" to besides 1, 0, or -1 that basically disables panning and
>zooming altogether?
>Thanks in advance,
>Mike Smith
>P.S. - Here's my javascript code that automatically loads/unloads layers:
> document.mapserv.submit(); //Note that my form name is "mapserv"
>Then I add this to my checkbox tag:
>onClick="UpdateMap();"
The information contained in this email and any subsequent
correspondence is private and is intended solely for the
intended recipient(s). For those other than the intended
recipient(s) any disclosure, copying, distribution, or any
action taken or omitted to be taken in reliance on such
information is prohibited and may be unlawful.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020909/a23ea384/attachment.html
