[mapserver-users] Compile problem
Miroslav Sodja
miroslav.sodja at gov.si
Tue Sep 17 09:50:01 EDT 2002
I compiled (in fact my webmaster did that) mapserv on linux with:
[user at host user]$ ./configure --without-jpeg --without-eppl
[user at host user]$ make
When I try to run mapserv:
[user at host user]$ ./mapserv
This script can only be used to decode from result and should be
innitiated as a CGI process via a httpd server.
I try included library:
[user at host user]$ ldd mapserv
libgd.so => /usr/lib/libgd.so (0x4001a000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40071000)
libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x4008f000)
libpng.so.3 => /usr/lib/libpng.so.3 (0x400d3000)
libz.so.1 => /usr/lib/libz.so.1 (0x400fe000)
libpdf.so.1 => /usr/local/lib/libpdf.so.1 (0x4010d000)
libtiff.so.3 => /usr/lib/libtiff.so.3 (0x4019e000)
libm.so.6 => /lib/libm.so.6 (0x401df000)
libc.so.6 => /lib/libc.so.6 (0x40200000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
Everything looks fine, but when I run browser like
http://www.go2ing.com/cgi-bin/mapserv the result is not
"No query information to decode. QUERY_STRING is set, but empty."
The result is very confused and looks like:
ELF!4°P4 (
44?4?AAôô?ô???~~?
¤oe
°"° ° /lib/ld-linux.so.2
Any idea?
Thank you,
Miro Sodja
e-mail: miroslav.sodja at gov.si
