[mapserver-users] RE: template file links with a "?" in it
Nicole Bömeke
bon at ivv-aachen.de
Tue Sep 17 02:50:13 EDT 2002
Thanks for the reply.
You were right that the ? is not the problem.
I checked the URL and it works fine now. :-)
Nicole
-----Ursprüngliche Nachricht-----
Von: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Gesendet: Samstag, 14. September 2002 19:01
An: bon at ivv-aachen.de; mapserver-users at lists.gis.umn.edu
Betreff: Re: [mapserver-users] template file links with a "?" in it
The ? isn't the problem. That functionality is amongst the oldest in
MapServer and I use it all the time. It's
got to be something else. What does the full layer definition look
like? Template checks for URLs just look
at the protocol and nothing more.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Nicole Bömeke <bon at ivv-aachen.de> 09/12/02 10:28AM >>>
I want to link different points in my map with different html files.
It works fine if I give each html file a name that contains the point
ID
and use the following template file link for the point query:
TEMPLATE "http://[host]/mapserv3.6_rrp_appl_NRW/[ID].html"
But what I really want to do is linking an active server pages file
with
each point.
The asp file gets the point ID and creates the specific html file for
the
point
by requesting information from an SQL database. I replaced the template
file
link above
by the following link but got the error message "Malformed template
name".
TEMPLATE "http://[host]/Sehenswuerdigkeiten.asp?dbspalte=[ID]"
It seams as if it is not possible to have template file links with a
"?" in
it.
Is there another way to tell the asp file the ID of the selected
point?
Thanks Nicole
Nicole Bömeke
IVV-Aachen, Germany
