[mapserver-users] Variations in label behavior between Mapserver 3.6.1 on Windows 2000 vs. FreeBSD UNIX
gisweb at lmi.net
gisweb at lmi.net
Tue Sep 17 14:07:01 EDT 2002
Hi List,
Any suggestions for how to resolve variations in label behavior between
Mapserver 3.6.1 on Windows 2000 vs. FreeBSD UNIX? The Windows 2000 version of
Mapserver produces correct labels that match their streets' angles. The FreeBSD
version of Mapserver produces incorrect angles--flipped or mirrored or both?--as
shown in the following web page: http://www.giswebsite.com/gis/problems/
Possible reason... An email in the archive (from 2000) suggests that older
versions of GD can cause this kind of behavior. There are two versions of GD on
the FreeBSD machine, both below the /usr/local directory. One was installed in
1998, and the other July 17th of 2002. The July 17th, 2002, version files are
in /usr/local/include/* and the 1998 version files are in
/usr/local/include/gd/*. When I specify --with-gd=/usr/local/include in the
configure instructions, the GD libraries stored in the /usr/local/lib directory
are thought to be missing, so the configure fails. The configure works when no
directory path is specified.
Any suggestions?
Jonathan W. Lowe
