[mapserver-users] Re: Compile problem
Miroslav Sodja
miroslav.sodja at gov.si
Wed Sep 18 04:15:17 EDT 2002
Thanks for your suggestion. The reason for that was, in fact, guiet
simple. Apache wants .cgi file to run mapserv as cgi executable. I
rename file to mapserv.cgi. It works.
Miro Sodja
e-mail: miroslav.sodja at gov.si
Miroslav Sodja wrote:
>I compiled (in fact my webmaster did that) mapserv on linux with:
>[user at host user]$ ./configure --without-jpeg --without-eppl [user at host
>user]$ make
>When I try to run mapserv:
>[user at host user]$ ./mapserv
>This script can only be used to decode from result and should be
>innitiated as a CGI process via a httpd server.
>I try included library:
>[user at host user]$ ldd mapserv
> libgd.so => /usr/lib/libgd.so (0x4001a000)
> libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40071000)
> libfreetype.so.6 => /usr/local/lib/libfreetype.so.6
(0x4008f000)
> libpng.so.3 => /usr/lib/libpng.so.3 (0x400d3000)
> libz.so.1 => /usr/lib/libz.so.1 (0x400fe000)
> libpdf.so.1 => /usr/local/lib/libpdf.so.1 (0x4010d000)
> libtiff.so.3 => /usr/lib/libtiff.so.3 (0x4019e000)
> libm.so.6 => /lib/libm.so.6 (0x401df000)
> libc.so.6 => /lib/libc.so.6 (0x40200000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
>Everything looks fine, but when I run browser like
>http://www.go2ing.com/cgi-bin/mapserv the result is not
>"No query information to decode. QUERY_STRING is set, but empty."
>The result is very confused and looks like: ?ELF?!4°P4
44?4?AAôô?ô???~~?
>¤oe
°"° ° ?? /lib/ld-linux.so.2
>Any idea?
>Thank you,
>Miro Sodja
